geoffreydean wrote:
If this procedure looks about right, I'll do some data collection and then possibly will have additional questions once I dig into Golden Cheetah/Aerolab.
Here's a little "bug" in Golden Cheetah's air density calculator: it doesn't take into account altitude. Official weather stations report barometric pressure as if they were at sea level. In order to get air density, you need to adjust for your actual altitude. (If you're close to sea level, you can use GC's air density calculator without needing to adjust).
Google maps or Google Earth (or any topo map, if you're old enough to know about them) will tell you the actual altitude of your start point.
I usually toss the first lap as I "settle in" and try to remember the line I'm taking through the corners, so it doesn't really matter whether I hit the interval marker at the top of a hill, the bottom, or anywhere in the middle -- I'm tossing that lap anyway.
If you already have GC installed, I often recommend that people just take a look at a regular ride they've done in the Aerolab tab. If the ride had any hills or rollers at all, you should be able to see places where the VE tracked well and places where it went off -- then think about what you were doing in those situations. For me, it's pretty obvious when I hit the brakes, or when I sat up, or when I was heading into or away from a headwind. The lesson, of course, is that when it comes time to test, you don't want to hit your brakes, or sit up, or test when the wind is gusty and unpredictable.
