hirochan wrote:
Hi Carl,
My SC9 came back to me. There found no issue on the frame and BB. Unfortunately, LBS couldn't fix rattle noise of the rear brake housing at shoulder and exit in the steering handle, saying a metal connection parts of the rear brake located on the top side of the SC9 frame should be pressed with stronger torque by the long housing cable.
So, my questions are, where the best place is to put the metal connection parts of the rear brake, and where better place is to place rubber parts (i.e. jog wire) to terminate the rattle ? Is it possible to show them in picture ? I'm using the far/mid stem.
As I've had a similar issue in the past (my metal connection piece was actually missing when the frame was delivered) let me first tell you that there is no real need to use the metal piece. The only purpose it serves is to make it easier to change the aerobar setup after the first build. With the connector you don't have to remove all of the cable housing but only the part within the aerobar. I in the end - I knew my position - did use a single piece of outer brake cable housing. So no metal to rattle. I'd suggest to do the same. if there's still some rattling - which can occur with the brake cable liner just hitting the inside of the down tube, I'd suggest to insert a longer piece of foam into the downtube. I had to do this, too in order to stop the rattling noises on rough roads.
Hope this helps!
Tim
