Quote:
Hi ian,
After consulting with my fitter and also QR, I got myself a 52 PRSix.
I am currently using a Pro Svet on my CD01 and I was wondering if you have any suggestions on the base bar to use?
Do I keep my existing Pro Svet or change to something else? If I change it, what would be a good alternative that works with a 52 PRSix?
Jeyps11_c,
There are a few things to consider here. I'm just gonna lay 'em out and you can marinate on the ones that matter to you...
1) Them bar clamp on that stem is 31.8 so there are no limits on your options as that's a standard size.
2) The ProSvet is a "winged" bar, not round so you can't really rotate the hand position for perfection without effecting how the wide, flat bit gets into the wind. If your hand position needed changing for greater comfort you'd consider a round bar.
3) The ProSvet kinda shoulders off and by that I mean the hand grip area sits lower (below) the center of the bar clamp (23mm). So if you're using a lot of arm pad pedestal (like 30+) then braking position sits even lower than that due to that fall-away of the bar. Euro pro roadies don't care about the elevation difference between their arm pads and their "pursuit" position but triathletes seem to do better when their arm pads and their braking position are not so far apart.
4) The ProSvet adds some reach to the position but not a tone: center of clamp to tip of pursuit is 153mm and it can't be cut down due to curve in grip. Something to consider if you wanted that position longer or shorter and you were looking for a new base bar to help in that.
5) Color - I've only seen the ProSvet in white and for those trying to get all stealthy, that might be an issue.
6) Money - base bars can run from $100 to $300+ If you like your current bar I'd rather you get several massages.
7) Carbon vs Aluminum - I'm not a huge fan of clamping carbon and your base bar will be clamped in three places. Carbon base bars are typically lighter than their alum brethren if that matters to you.
Hope this helps, Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
