Quote:
I'm finally ready to buy a Triathlon Bike and i'm hoping you can help me out.
I have no idea where to start as i'm kinda pinched for time between work and raising two little kids. The QR website chat person told me i'd fit a 52cm X-PR, my local bike shop said i'd probably fit a 54cm Felt IA or B. Is this close enough to make a purchase?
I'm 45yo, pretty fit, 5 foot 9 inch 148 pounds living in north/central NJ. 79cm inseam. 95cm saddle height from floor.
My current bike is a 54cm 2009 Trek Madone with clipon aero bars which i had to buy a longer seat tube for because the original one it came with was just over the maximum safe height. I ride this bike about 4-6hrs per week and did IMMD and IMLP on it in 6hrs and then ran a 4hr marathon so i'd say my current fit is pretty good for a road bike.
Any help is appreciated. Let me know if you need more info.
metaprinter,
Here's what's cool about a guy like you switching from a road bike clip-ons to a pure tri bike position.... that 6 hour Placid split followed by a 4 hour run will probalby drop down to a 5:40 bike split and a 3:50 run - and voila! You'll be gifted 30 min just from the position.
Based on the info you've give me: morphology (longish legs), past position, healthy, and fit.... I'd say your Pad Y is roughly 630 and your Pad X is in the neighborhood of 445.
The QR X-PR comes with some different options for the front end and I'm going to describe & prescribe those so you can move forward with your purchase decision fully informed... and, here are a few notes and give you faith in my recomendations: I'm a bike fitter -sure, anyone leading a thread like this better be. I'm also a USAT Level 3 Certified Coach and have been coaching triathlon, full time for over two decades. That's the history, those are the qualifcations that guide my advise to you below.
Option 1) QR X-PR size 52 with what I'm going to call the "mortal" front end. It's the Profile-Design 1-Seventeen stem, and Profile-Design 35a aerobar extensions. You'd want to choose the 90mm stem (QR offers a 110 and a 75mm as well), have it positioned in the -17 degree position (this stem can be flopped to be +17 as well), under the stem you'd need 10mm of spacer and under the aerobars you'd need 20mm of pedestal. The arm pads would be mounted dead center in the range. This is my favorite front-end option for you because of ease of adjustability. If Pad Y of 630 feels to low you can go 40mm higher - if the 630 feels too high you can down 30mm. If the pad distance feels to long you can shrink your cockpit 27mm or extend it 32mm. There's lots of room to move to find perfection with all the same hardware. There will be a tiny bit of cable exposed but not much.
Option 2) QR X-PR size 54 with what I'm going to call the "super" front end. It's QR's own, OEM "Aero Stem" paired with a Profile-Design Aeria Ultimate aerobar system. The stem would be the 90mm (there's a 110 and 75 here as well), the stem can only be positioned one way, you'd need 10mm of "stem stack" (the bar clamp has clam-shell spacers in it, you'll have one below and one above the base bar to get the height right) and under the aerobar you'd need 15mm of pedestal. The arm pads would be positioned 4 holes foward of all the way back. You'll have room to move here too: 40mm up, 25mm down...22m shorter cockpit, 50mm longer cockpit.
Option 3) QR X-PR size 52 with the "super" stem but the basic, P-D base bar and 35a aerobars. 10mm in stem clamp (one half of the shell below, one half above the base bar) and 25mm of aerobar pedestal. Arm pads 3 holes forward of all the way back. Movement range is 15mm higher, 25mm lower, 15mm shorter, 50mm longer.
Considerations...
Cranks: get the shortest cranks (160mm) on the bike. 52x36 rings are fine paired with the 11x30 12 speed cassette
Money: the Aeria Ultimate bar is ~$1,000. I'd rather you spend more to move to Ultegra Di2 over the 105 (ultegra is lighter).
Aesthetics: how your bike looks is important - get a paint color and that will love for a decade into the future.
Hydration: we're talking BTA here (Between The Aerobars) - if you want the super sexy Aeria Ultimate hydration system you have to get the Aeria Ultimate front end. I think the Profile HC-800 BTA is VERY good and can be attached to the mortal front end.
Wheels: (maybe this should be under money too) if buget is tight get Ultegra Di2 groupset and stay with the basic wheels - and upgrade the wheel set in a few years time. If can swing it now get the Hed 60mm deep.
Get back to me here if you have any questions
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
