the difference between you, an "amateur", an a pro, is not your chassis. it's your engine. your fitter has the equipment you need to do this experiment. it would take 5 minutes to set that bike up with the pade 30mm or 40mm further forward, the saddle maybe 20mm or so further forward (or not, it looks pretty steep), and the pads 40mm or so lower. (maybe with the armrest pads 10cm or so lower than the saddle). and if you did that you still wouldn't have a "pro" position but it would be close.
ride that for 4 minutes. ride the position she has you in for 4 minutes. ride them both at a high power (maybe 200 watts). decide which you like better. buy the bike based on the position you intend to ride.
look, if i ask you to perform a bench press, do you do it differently because you're an amateur than a professional body builder? i doubt it. the best way to perform a bench press, the most efficient way, is the same whether you're pressing 150lb or 450lb, is it not?
the pro position is not an uncomfortable position. it's the opposite. it's the most efficient way to get through 56 or 112 miles. furthermore, the QR you want to buy is designed for that position. so go get fitted in that position, and report back whether you were comfortable and powerful in that position. and then let's prescribe a bike.
also, alert your fitter that we have a bike fit workshop upcoming november 6 thru 10. we'd love to host her and she and i can debate and talk and share and perhaps we'd both be the better for it.
these positions are not radical or aggressive. they're typical, powerful and comfortable. i would love to see a photo of you on your fitter's fit bike in a position that looks like this, and then here from you if you found this too extreme. if so, then work back from it. move the saddle and pads back 1cm and the pads up 1cm. and then again. until you find a really comfortable, powerful position.
Dan Empfield
aka Slowman
Dan Empfield
aka Slowman
