Quote:
Hi Ian!
I'm looking to buy my first TT bike, specifically interested in the X-PR based on the available features (Di2, paint options, etc) and budget. I'm coming from riding a road bike that I bought secondhand on FB marketplace - a 2019 Liv Avail SL 2 Disc, size Medium. I had a fitter fit me to this bike, but unfortunately he's out of the country for the next month, so I haven't been able to get TT bike fit measurements before looking to purchase a TT bike (a bit motivated based on the current QR spring sale to get an order in!).
I'm female, height is 5'6, inseam is around 31in. I chatted with someone at QR who said the size 50 frame would fit. I'm leaning towards the Aeria hydration system, not sure about the bar extensions (is one "better" than the other aside from alloy v carbon?).
Hopefully that's some info that can help in pointing me in the right direction in terms of fit. Thanks so much!
klondikebar,
You've given me some good info here and I suspect your Pad Y is around 600 and your Pad X is ~425. As you've already noted the X-PR comes in a couple of different front-end options and here are the prescriptions and opinions on all of 'em....
X-PR size 50 with a 90mm QR Aero stem, the Aeria Ultimate basebar and Ergo 35+c aerobars. You'd need 10mm of stem stack and 25mm of aerobar pedestal. The arm pads would be offset -5.50. I like all this because you have lots of room to move the pads up, down, fore, aft to find your exact spot. The QR aero stem and the Aeria Ultimate bar is sexy sure but it also allows for Profile Design's Aeria Ultimate BTA (Between The Aerobars) hydration system to plug in seamlessly.
X-PR size 50 with a 90mm QR Aero stem and the Sonic 35a aerobars. You'd need 10mm of stem stack and 15mm of aeobar pedestal. The arm pads would be offset -5.50. Same room to move up/dwn/back/forth. There are a couple of differences here and one of them is that the elevation from aerobar to bullhorns (AKA "pursuit positon") is 15mm, while the Aeria is 25. That's not a huge difference but one that might matter to you. Yes, the aerobars here are aluminum vs carbon above.
The "35" in the aerobar is the angle of the bend - it's a "ski bend", you can see it here
https://profile-design.com/...5c-carbon-extensions. If you look in the "description" drop down it says the carbon ones are 262gms/pair for the 400mm length and then compare description on the aluminum ones
HERE is says the extensions come in 340 & 400 and they are 200gms/pair. That's curious. Anyway... I like clamping aluminum better than carbon and the extension get calmped.
You can also do the X-PR with a "mortal" stem..
X-PR with a Profile 1/17 stem and Sonic 35a aerobars. This could happen no a size 48 and a 52....but I like the look of the size 50 with a 110mm stem in the -17 degree position with 15mm of spacer under the stem & 5mm of aerobar pedestal and then pad offset -6:25.
X-PR with a Profile 1/17 stem and a Supersonic Ergo+ 35c aerobar. Same as the one just above: 110, -17, 15mm spacer + 5mm pedestal, pads offset -6:25.
Let's say for a set that you didn't care about aestic of the QR Aero Stem - I would argue that the PD 1/17 stem might be easier to pack into a tradition bike box for flying/shipping.
You can't go wrong with any of these you just need to decide on budget, BTA preferences, and the look of the stem.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
