Quote:
hi ian, im working back and forth between several bikes for the new season and going forward. im currently on a "long and low" bike and i dont want to move away from that.
Stack to middle of a 12 degree tilted pad is 625
reach to back of said pad is 495
BB to seat center is 750.
the new QR PRSix 2 is very alluring due to the integrated hydration. im looking at that, a shiv disc, and a cervelo P5D. i was set on the shiv but looking at the wheelbase i have ruled the bike out pretty much.
per the x/y fit, i would be fit right in the middle of the x/y possibility on a 52, however looking at bike dimensions i would be able to do a 54, i would be slammed (one 5mm spacer) but it would get me a bike thats very very close to the standover / wheelbase of what im on now.
damon.lebeouf, Let me workout both bikes first...
The QR PRsix2 in size 52 would have the 110mm stem with the bar set up with the middle (sandwich) clamp and 15mm of pedestal spacer. The armrest bracket would be forward and the armrest would be mounted in the middle hole. You'd have 30mm more in reach on this bike if ever you needed it (and 90mm less). You could also go down 25mm lower if needed (and up 70mm).
The QR PRsix2 in size 54 would have the 90mm stem with the bar set up with the lowest bar clap position and 5mm of pedestal spacer. The armrest bracket would be rearward and the armrest would be mounted in the rearward hole. As you've already noted you could only go 5mm lower and you've have lots of cockpit, both fore and aft with which to play.
You've already given this some good thought. I like the set up on both bikes. The one thing that I can add with most certainty is this.... as triathletes age pretty much all of them don't go lower in arm pad elevation, they go up. I assume you're getting older just like the rest of us so don't fret over the nearly slammed 54, my guess is that you won't be going lower on your already long and low position.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com
I like the pursuit of mastery
Twitter - @TriCoachIan
