Quote:
Quote:
Ian,
I am looking to purchase at QR XPR and am wondering the correct size. I am riding a 54 cm Cannondale Slice (2005 Aluminum), but I am worried it is too small because of how low the bars seem to have to be compared to my seat height (and my recent Trek experience see my post below), and back fatigue/pain (I have no back problems otherwise) at even an Olympic race, so I would rather fit based on my personal measurements. I don't fully trust fit coordinates as they are on the smaller frame.
Using the formula method, I am 176cm tall, my inseam is 86cm, and my seat height is 78 cm.
What is the QR size for me?
Thank you!
Rob,
I get that you are weary and I can easily see how/why you've ended up on a bike where the whole frontend (base bar, arm pads, aero extensions) was too low. You've got long legs for your height and that demands that the set-up is "short and tall" (as opposed to long and low) so the pads need to come up and back to meet you. You can still be crazy fast in that position, and, as you've noted, comfort is critical.
I'd guess your Pad Y to be around 650 and your Pad X to be ~430. You should get an XPR size 54 - and get it with the Profile Design 1/Seventeen stem* (NOT the QR aerostem). Get the PD 1/17 stem in 90mm length, set in the -17 degree position, with 15mm of spacer under the stem and another 15mm of aerobar pedestal, and then pads should be set -7cm of off set (which is 2 holes forward of max back).
Let's stay for a sec that my assumptions are off - not likely, I'm an expert in this and I've had years of practice with thousands of atheltes - but if I'm off a bit you'll be able to move the pads all over the universe: up 80mm higher and back 30mm closer WITH THE SAME 90MM STEM. You can also go a long longer (50mm) and lower (30mm) but that's less of a worry in this case. The reason the ranges is so great is that *this stem we're talkin' about can be flipped to a +17deg position and gain a ton of height. Also, this stem is inexpensive, they make it in lots of lengths and you can give this bike a ton of range in the snap of your fingers. Also, the bike will come with a bag of profile design spacers and bolts of differing length - this is the pedestal system to lift and lower the aerobars so you can get the frontend exactly where you need it.
Get back to me here if you have quesitons but I'm confident in this so order before the sale ends.
Ian
Ian,
So in my case, I know you are recommending the 54, which sounds like I will have to have a very tall front end relative to the frame top tube. And I'm fine with this and am not doubting your background, experience by any means. But, most size charts/finders seem to place me on a 56 (Cervelo, Trek, etc.) and I also know each bike is different. But I couldn't imagine raising the bars on my C'dale as it would be so high on the front relative to the top of the frame and probably pretty tippy. If I were to go with the 56, would it even be possible to achieve the fit with a lower total front end relative to the seat height? (Shorter stem, less spacer height, etc.)?
Thank you for your time.
Rob
Ian,
I have attached my fit on my Med Trek SC. We had to get a seatpost with set back, and raise the front end so high on this bike. This position was not super comfortable, and handling was not great as the front was so high. I did NOT get a pre-fit, which is what I should have done, and as I think I stated, I had to sell the bike. I do not have the fit coordinates of my Cannondale which is far more comfortable with handling and power, but just not great for longer/harder rides on my back (but it is much lower on the front), but I could measure if you think it's necessary for you to determine.
Yes, this is why I am weary, and just want to eventually be on the right bike...and this is why I am reaching out here to work on this process with experts.
Is QR even the best bike to achieve a good fit for me, or is there a better choice? (for instance the Cervelo Head Tube length is longer/taller at size 56).
One more thing if it matters/helps. I rode a 1990 QR Superform 55cm. This was my first bike, and all of my best times were on this and I remember it being much more comfortable for longer rides (i still have the frame). Based on my own measure, frame stack was approx. 50cm, and reach was 42, similar to my Cannondale, but the head tube length was 14cm and the Cannondale's is 11cm.
OK, I'll stop now :) Thank you again so much for all of the time on this.
Rob
Rob,
I'm with you 100% here and I don't want you to "eventually" get on the right bike - I want you to immediately get on the right bike. It's funny but, as a fitter, and epspecially a fitter who works with atheltes on this forum and within this buying process - my #1 purpose, my raison d'etre is to get you on the proper size with the exact front end necessary for you to be comfortable first, powerful while comfortable, and aero if we can get it (and we can).
You're poking around the answers here so let's cut right to the HUGE difference betwen the ol' Slice and the new QR XPR: the Stack of the 2005 54cm Cannondale Slice is 509mm. The Stack of a 54cm QR XPR is 540mm. The frame of the QR is 31mm taller than the Slice. That's a big number and it's a big number headed in the direction you want to go. Also, "sounds like I'll have to have a very tall front end relative to the frame top tube" Nope. My prescription is a 54cm XPR with a 90mm stem in the -17 degree position with 15mm of spacer under the stem and 15mm of pedestal. A -17 stem (level to the ground) and +15, +15 is not a tall set up. A tall set up would be a (PLUS!) +17 degree stem with 30mm of spacer under the stem and 40mm of pedestal. By the way that prescription (90mm stem, -17deg, +15, +15) is 90mm
LOWER than the example of the tall set up (90mm stem, +17deg, +40, +30).
You could also fit on a 56cm XPR and, by the way, the Stack of that bike is...logically...560mm. The front end on that bike would need to be a 70mm stem in the -17deg position w/ 10mm of spacer under the stem and no aerobar pedestal (slammed) and pads offset -6.25. I didn't spec this size for two reasons: first off as I like the idea of a 90mm stem adding to the stability of the steering but a 70mm on a 56 is fine too, and second I like the aesthetic of a wee bit more post exposed out of the frame - but I'm a bike snob, so we have to factor that into the equation.
And... don't stop now. If you have more questions, want more clearification get back to me here.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com I like the pursuit of mastery
Twitter - @TriCoachIan
