Here's a data overload post but ties several of the topics discussed in this thread
First of all, I don't like protocols. I like to ride, do my workouts and if I can get aero data, great.
I absolutely appreciate that protocols allow to get more accurate data, especially when no accurate sensor exists. The same start/end point gives a delta Elevation = 0, no need for altimeter. Out and back averages wind out, I get it......
But the more accurate sensor data we have, the less need for strict protocols. The more data, the easier to find and correct errors. There is value in sensors that can do this, IF they do this. Rant over.
This data is part of an exercise I am doing in preparation for another project. The idea is to explain what sensors can do.
Here is a ride I do regularly, out 7km, back. Rolling hills, and part East/West, part North/South. You get it all, wind, yaw, up, down..... It's also the course I race weekly and I love getting real race data at much higher speeds.
Chart 1
So here is a Chung VE plot with only the Garmin data. In green, the altitude, in white Aerolab's VE plot.
The altitude sucks. My 520 has a crappy barometer. The VE curve shows quite obvious head wind and tail wind.
BTW, I have a version of Aerolab that re-syncs VE to altitude at selected laps. 2 is an out, 4 a back, 6 and out, 8 a back
Chart 2
Overlay speed and airspeed (airspeed - speed = wind)
Notice speed varies considerably. No need to hold constant speed or power
Top green is speed, blue airspeed. We see the general trend of head wind out (blue above green), tail wind back (green above blue). You can see mirror of wind patterns on the out and backs but not always perfect
Now let's correct the altitude with a high precision barometer, accelerometers and 3 other sources of data. One of those sources is broken here, I'll explain why later. Correct altitude in yellow
Now let's calculate a VE using the wind and see how it matches the corrected altitude.
VE with wind in white. Altitude in Yellow. Laps 4,6,8 are much better
Let's correct the CDA for the first lap to show the sensitivity here. I just moved the CDA slider
ST is preventing more charts, so I'll continue in another post
