burnthesheep wrote:
MrTri123 wrote:
What was the difference in watts between the 3?
Watts depend on what speed you're personally going.
For me the CdA difference POC to Aeroswitch was .007 to .009 (depending on tossing statistical outliers of lap data). The POC to the Giro was more like the Giro being .014 to .016 slower.
Again, that could be a small amount at a slow riding speed making the difference for someone in longer events like triathlon largely irrelevant. OR if you're doing just 3km or 4km individual pursuit.......the watt delta could start to grow into a fairly meaningful amount.
You'd have to plug those deltas into an online calculator with your desired speed and CdA to see what happens.
Aeroweenie's calc at 25mph the best to worst is about 13w, the middle was 7w. I time trial a 10 excluding the u-turn at about 28mph..........so more loss.
I already owned the POC. So really just proved to myself something to not LOSE. Not really a gain at all.
Then again, not sure how relevant 28mph or even 25mph is for someone that isn't a pro or really quick amateur triathlete. As you're largely in Z2 or Z3 bike power for those, not Z4 and low Z5. So it's almost an order of magnitude different scenario.
Quick trick :
You can ignore this part, it's just for understanding and you probably already know
aero watts = 0.5 * airDensity * CDA *airSpeed^2 * airSpeed.
Assume no wind so it becomes 0.5 * AirDensity * CDA * airSpeed ^3
So at 36km/h (10m/s) 0.005 difference means 0.5 * 1.16 * 0.005 * 10^3, so
0.005 * 580 = 2.9watts
At 46.8km/h (13m/s) 0.005 means 0.5 * 1.16 * 0.005 * 13^3 so
0.005 * 1274 = 6.37watts
So the part to remember
At 36km/h about .6 watts per .001
At 48km/h 1.3 watts per 0.001
