I'd please like some input on some misfit in my testing. I've attached a screenshot from GCNotio, showing some areas of misfit between measured and virtual elevation around the smaller turnaround on my halfpipe course. This part of the course is least well sheltered by hedgerows, and on this particular day there as a light crosswind according to weather station data (~7kph). I can rationalise this misfit as being due to poorly captured headwind/tailwind components along this stretch, since they approximately seem to cancel. The effect seems to be worse on runs when the windspeed is higher
I'm using the out and back of this course for Notio to calculate the calibration factor, which is repeatable around ~1.38. I have it mounted using their supplied mount underneath the extensions, but due to the narrow gap between them (and shape of my extensions) offset to one side rather than centrally. Has anyone had good results mounting a notio on the end of a boom, which should lessen the asymmetry?
Any other advice also gratefully received!
