burnthesheep wrote:
If you care about absolute CdA, the inclination being the same % grade the whole way would matter. As the accel/decel from road changes the GPS elevation cannot pickup would cause error in the calculation. But, if just interested in differences of setups........you're covering the exact same piece of road each lap.
In my feeble brain, for "this is better than that" testing, the only variables lap to lap on same setup are:
-body position
-vehicle passing
-irregular wind effects
-irregular cyclist speed control (accel or decel affects the maths)
They didn't re-grade the road between your laps. They didn't repave it a different CRR material.
You KNOW when a car passes, so add a lap to that set and remove the one lap from the dataset. That variable is gone. Irregular cyclist speed control is an issue if you have "small" bumps in the road causing you to slow or speed up and alter your power plan. This is where road grade being consistent helps a lot for a longer out/back kind of laps. That helps reduce that variable.
I try to get rid of that variable by even if a loop has elevation, I mark it as "velodrome" in GC. It's the same strip of road each lap. Sure, you get a little pimple change in CdA each lap from your accel/decel.......but it's the same pimple.
I have tried this on a 1/3 mile neighborhood roundabout that had a pretty solid little tilt to it. Laps were very consistent on CdA once I told it "ignore elevation".
Issue has been for me with cross winds testing with the disc wheel on the back for out/back laps. The sensor doesn't feel all the cross wind it seems and the out lap is higher CdA, then on the "back" lap the sensor downwind isn't seeing it and the CdA goes really low. With that, I need to just build myself a little wind sock to take with me for the day so I can eliminate that variable by picking the road that's perfectly against/with the wind.
I found a lap I want to try but parking is risky. Don't want to get shot. I may need to park 5mi away and ride with a musset bag of my fit parts or tools.
This is about a 15min drive from my work: .36mi per perfect circle lap, would need to choose days wisely as wind down east can be shit
35°34'34.0"N 78°16'02.7"W
35.576112, -78.267413
A couple of things
If you do this downhill only test, you could get pretty good "this is better than that" if you control the things you mention (wind, cars...). One problem with those tests, is if you get speeds that are "high enough" your CDA will vary in a measurable way. Your CDA measured at 30km/h and 70 will be different. So yes, you can calculate a form of "average" CDA, if you have an accurate delta-altitude and accurate start/finish speeds. But wouldn't you like to know what your CDA at various race speed is ?
If you had a device with all perfect sensors, you'd be able to see a plot of this varying CDA with speed.
If you have "ok" sensors at least you can determine where weirdness such as varying wind occur.
If you have "suboptimal" sensors, you need to compensate with more protocol.
I personally am not a big fan of aero testing with a disc wheel. It doesn't take ridiculous conditions to make test A and B quite different because you get a "sail effect" on one run.
BTW, we can log, with a Varia type sensor, when there is a car. But I hate throwing out a lap because of one stupid car. This is where more "instantaneous CDA" becomes really nice. If you have 5km stretch where you are constant at .25 and there are "blips" where you go to .26 and you can explain those blips, then you know you were a .25. If you have "Varia type" data, that is one way. Another is to simply not pedal for 10 seconds and when you are doing your analysis, if a CDA blip corresponds to a cadence=0, then you know something happened there. BTW, very often you see it in the airspeed data.
Imagine you had done a 20min FTP test, and you held 320w for the whole thing, perfectly even but at minute 12, there was a drop on the Garmin and you lost 30seconds of data. So you lap average is now 312w. Wouldn't you like to see that perfect 320 before the drop, after the drop and say "I did 320" rather than throw the entire test out the window. That is exactly was the rolling CDA could/should give you, but it requires really good sensors to be accurate.
And if you have good rolling average CDA and you have a plot of wind yaw, you can see things there.
Again, there are all kinds of ways to overcome deficiencies in sensors with protocol but if/when we nail the sensors way, way more data becomes available to us, including things for example the ability to separate CDA/CRR
This is why I think the manufacturers need to continue pushing the boundary of sensor accuracy. It's not an all or nothing thing. What's out there is better than nothing, but there is a whole lot of improvement that can still be done. And yes, they are not all at the same place today.
