AeroTech wrote:
burnthesheep wrote:
Question:
Are some of the really really low CdA's we see from top TT, pursuit folks attainable by folks at lower speeds? Or is it such that there is a theoretical low per your body/bike based on your speed?
Like.....a pro going 32+mph could have a minimum CdA of like 0.180 but a joe going 27mph only a minimum of 0.200 or something?
Currently at the World Championships in Belgium, and the TT earlier in the week had some impressive numbers. We have seen in wind tunnel tests as well as road tests with the AeroLab sensor (following Crr calibration) some riders do indeed achieve sub 0.17 CdA, but they are absolutely at the top level world-wide. Moreover, the sub 0.17 was indeed only achieved after years of training, and includes some very unique aspects such as custom design skin suit boundary layer trips leading to a significant decrease in CdA beyond about 39-48 kph (the effect is local, so there is no one single magical speed you need to hit).
The riders at worlds were hitting 49 to 54 kph average speeds for the 48+ minute solo effort, nearly 34 mph. Keep in mind several technical corners required the riders to slow down, even brake, and this usually does not factor into the math of what is truly needed to be going this fast on average. The riders have no choice but to be sub 0.19 CdA in order to be competitive. Our Worlds TT course-specific math was showing a 0.2 CdA would require approx. 475 [W] for sub 48 minutes in order to be on the podium. When you drop CdA to 0.17, you get closer to a humanly possible effort in the neighborhood of 400 [W].
Thank you for this. We are doing some simulations for a WT team with the Tokyo and Worlds course and your number make sense. We will be off your numbers a few watts here or there, but this is what I am thinking
Only 2 guys went under 48 : Ganna and Van Aert. I don't have their power files but I am pretty sure they were north of 400w. Those guys could be much closer to .190-.195 and hit the times they did. Ganna ,I am pretty sure would be closer to 440watts. What a monster.
You go down the list and they are all big power guys. While they are not Ganna, they are much closer to 400w, and their time delta with Ganna is not in line with massive CDA improvements. That .19ish 400w range aligns with their time behind the leader.
Then you have a guy like Dan B. 16th place, 2Min 11 seconds down. I have never seen a Dan B power file, but let's pretend his CDA is .165 like some of the rumors floating around. He would need about 340-350 watts to do it in 2m11 down. I suspect he is more powerful than that. At a .17 somewhere between 350-360w. I can see this.
My point here is I believe VERY few people are in that .17 range. Very few are able to reproduce on the road and in typical race distances. The winners are still producing BIG power numbers. I do have the files of the guys that are closer to 0.20, do close to 400 watts and their times are pretty aligned with this. But they are 2.5+ minutes down. They are (IMO) the pretty dialed, pretty strong riders in the WT. Not the Dan B aero bullets or the Ganna super engines.
You are right these are guys extremely dialed, the very best equipment. No tri pros or amateurs are getting close to them. But I think the guys that can do .17s on a road TT are pretty, pretty, rare.
If you have files from the Olympics we can compare to those as well but so far I am seeing the same trends.
All this IMHO
