burnthesheep wrote:
Loop didn't work last night. Despite best Strava sleuthing, it had appreciable elevation change per lap. I wasn't too concerned with this but it caused me not to be able to reliably hold speed or power in a way that wouldn't likely screw up the CdA calcs. Introducing error or variability in calc. Meaning, I had to ease off way too much a few times near the bottom of the loop.
Despite this environmental test setup issue, I went ahead to get some data to play with this more.
A few comments about the GC Notio aspect of things:
1. I thought I was going nuts, but I swear I created two identical intervals in GC for the same data set and the POS spit out wildly different averages for CdA. Identical time range for the interval. Off on average by 0.005. Yeah, that's not confidence inducing at all. Not pleased with that discovery.
2. The average shown in GC for intervals often doesn't make sense versus the displayed data curve. The data line or curve may vary +/-0.005 high to low, fine. But the average will be equal or higher than the highest value on the data line there. Like, what? I dug into this a bit looking in Excel instead and didn't see any weird spikes. So not sure what the error is in GC. I got more reliable averages for an interval by using the CSV file export, converting to excel, adding charts, and going that way. In Excel I basically found the spot I had started getting a speed reading, and added 30sec worth of delay to the average since that's what the Notio has setup. Then sub'd 30sec off the ending time just to be sure.
Comments on the Notio from this test set:
1. The air density given was 1.15 to 1.155 for the run. The local weather station literally up the road, which I trust more, came out to 1.166 for the same period. A 10% difference. This caused the "actual" CdA to be "off" in my opinion. Not a huge deal so long as it's consistent.......but I'd have hoped it would be a bit closer than that. If the weather man swore to you it's going to be 80 tomorrow and was off 10%, 88 isn't a huge deal but 88 is a lot less comfy than 80. Right? Same here. It's just enough off to not be pleased.
2. I keep getting CdA's that given the terrain, power, and speeds are many points too high. I plug the data into Aeroweenie calculator or my own Excel one for a whole run average and even ignoring not putting in elevation to those calcs get a lower CdA. By about 0.015. Using the same air density, power, weight, CRR. For my 10mi run same data in Aeroweenie gives me a 0.233. But the Notio and GC data gave me more like a 0.245. I trust that the 0.233 is a lot closer to reality, and even would be higher than reality given the route had terrain to slow you. Whereas the calc is for pan flat.
So far, not super pleased. I understand the value Rchung above posts about preferring to suffer on the laptop in comfort of home instead of lots of runs.........but so far the data isn't very reassuring sitting on my couch.
I've attached the JSONs for all last night. The 10mi run is bigger than zip file even for 250kb max.
So a couple of things
a) I've seen some of the warts of several of these products and their benefits. I've tested a few ( more than 2:-) ). Some are better than others. Some require more tweaking to get good numbers, some are more subject to user error. Best to get to the bottom of it before throwing in the towel....None of them are perfect (yet) but some of they give (or will give) data that is useful. I really wish DCR would do a review of the state of the nation
b) Don't worry about the air density. It doesn't use air density in it's calculation. It uses air pressure therefore doesn't need density. Now, wind may be off because it has to go from pressure to speed, but that won't impact your CDA.
c) If you believe your CDA is too high, one problem may be the calibration. Remember if it's ready low air speed, it will give a high CDA. Look at it in VE chart. What does the wind pattern look like ? Strongers tail winds than head winds ?
d) .005 is not that big an error. It's big but not crazy. Some will claim they get .001, there are people in the tunnel that get nowhere near .001. I have seen pros get .005 at Specialized tunnel. I think DD said he sees a .003 at the tunnel (by memory).
e) remember that in the running averages in the chart. If the average is higher than the highest, check if there isn't some very low numbers in the seconds preceding the lap start. If your laps are more than 60 seconds see if the average is higher than the highest after 60s. Maybe they have a bug.
d) coming back to A, you can analyze the underlying data of these devices and figure out if they have a hope of calculating a correct CDA. I don't mean this for the Notio, I mean it for one specific product, but the class of products. In the best case you press a button and get a CDA. In the worst case you have better data to calculate a better CDA on your own.
