Tom A. wrote:
ericMPro wrote:
how do you compute exactly the frontal area of the ball and the exposed stick?
E
Measurements and geometry? ;-)
Seriously though, I think what you're getting at is how did I account for the stick portion as it's attached near the bike, right? Simple, I made the "baseline" the setup WITH the bare stick attached. Since I was mostly interested in relative changes from that point (to prove out the sensitivity to the various size spheres) that made sense. If you read the blog post, for the "stick only" attempt, I even place a thin washer at the end of the rod to act as sort of "endplate", mostly because I understood the spheres would end up affecting the flow over the stick in a similar manner (i.e. the flow would be mostly aligned with the flow, whereas without an endplate, there would be some skewing/vortices at the rod end). I wasn't sure how much that would matter, so I decided to use the thin washer, to at least minimize any effects.
I made sure to also subtract the length of rod covered by the spheres when they were attached, to get a better "calculated" CdA difference between setups.
Thanks, yes, you got my meaning and not what I literally wrote. Enjoying the blog post now...
E
Eric Reid
AeroFit |
Instagram Portfolio Aerodynamic Retul Bike Fitting
