marcag wrote:
Do you see consistency in your calibration numbers ?
Do you see them changing in a consistent way as you change your stack ?
When comparing numbers you have to have strong confidence in that calibration number which means consistency.
If you do a run and get a 1.38 then change nothing and get a 1.37 you cannot compare the two numbers if you use different factors.
Different days and roads the factor may change, but same day same road and doing a test of things I do not see it change. It stays.
Today I pit the Aerohead, Aeroswitch, and Tempor against each other at the modestly higher stack. Number crunch tonight.
One way or another, the power drop off would matter with the lowest stack. As I'm slow enough versus a "pro" that if a pro loses 5w or 7w of power from stack height hip angle stuff, that's 5w out of 400w+. 5w for me is out of like 280. So more difference.
I feel like the lowest stack also isn't good as looking at a photo of it, it doesn't seem to get me any favors in a side view of my frontal area and my chest/back at all. Like, the higher stack is "already low enough".
Thoughts on those helmets:
-Aerohead has less visibility with that little point between your eyes but with such a giant visor than I would have assumed. I like it as a helmet, but didn't find wearing it life changing at all. I'll change my mind if the data favors it. Road/wind noise with it was average I would say.
-Aeroswitch has better visibility due to how the helmet cocks back to your back and you've got that whole visor. I didn't care for the wonky optics closer to the road in front of you versus further down road. Road noise was highest of the three. Felt quality, liked wearing it. Maybe a bit warm/snug on the ears for a summer lid.
-Tempor, neutral visibility. Again, since it is cocked back you can see where you want. By far quietest to the point you don't really have a sense of how fast you're going or not versus the other two. Other two you can kind of hear the wind noise enough changing it you could kind of gauge your air speed.
Overall, all sat fine for the fit. Sun on this road this time of day is "just so" that on the outbound test leg you can without moving your head see out of your side eye a shadow of your position.
I may have to do the same helmet test again another day as today would have qualified as "high yaw". I would be shocked if today the Tempor still did well at all. Not really a day for that lid.
