Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [The GMAN] [ In reply to ]
I may be right behind you. I'm having trouble finding a reason not to buy this bar.
Thanks for starting the thread!
Scott
How did you select your stem length? What are your plans for BTA and computer mounts?
Scott
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [GreatScott] [ In reply to ]
GreatScott wrote:
-Any concerns about running Magura RT8 brakes on the AU?
Nothing I can think of.
Quote:
-The reach from the BB to the back of my pads is 485, of which 437 comes from my size 58 P3 frame. How would you recommend replicating those numbers with the AU? In other words, can I get there with the 70mm or 100mm AU stem?
And now we come to (part of) why PD engage my services as a consultant - I've modelled the fit options of most aerobars on the market for the velogicfit bike finder so can calculate the fit for most bikes/bars.
Your Pad Y still 660?
Accuracy is radial distance from target in XYZ.
You might choose to slam the steerer spacers in favour of more under the pads. So 10mm on the steerer and 30mm under the pads will move x forward 3mm and should give you enough clearance to use the Bridge and BTA.
The integrated bottle is still a few months away from hitting the market. It's not an easy thing to make.
Velogicfit bike geometry comparison l Speedtheory
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [cyclenutnz] [ In reply to ]
Wow, thank you! Very helpful, great advice.
Love the idea of 10mm on the steerer and 30mm under the pads.
My Y is currently 665, so very close!
Is the Z (100) in your model referencing the 100mm AU stem?
Scott
Ext Z is the separation of the extensions (c to c in mm) - which is fixed on this bar but becomes an important variable on clipons (hence inclusion in the models)
Pad Z is the armrest width (c-c)
For 665 you could just add in the bridge (5mm) on 30mm spacers
Ahhh, I see. Fwiw, my pad Z is 245. Based on what I've seen elsewhere, I should be able to get there on the AU?
Sorry if I missed this, but which stem did you model / recommend?
Scott
closest pad centre is 252mm, note that the F40 will effectively be wider than most so you might want to go in a step from there
For the stem - I've highlighted the relevant cell
Not sure how different the bar is but it looks like the New Cube runs Profile bars with Magura brakes.
I wondered if the drink system on the Cube is also Profile Design as it looks quite similar to the new system.
Got it, thanks again! You are tremendously helpful.
Cheers,
Scott
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [boing] [ In reply to ]
The cube uses the brackets from the Aeria Ultimate but their own basebar.
I haven't seen any images of a drink system for it, I don't know what they're using.
Scott
Trisports only had the 70mm stem left so that was chosen for me. :-)
That stated, I would have selected the 70mm anyway since I only need about 75mm of effective stem length to get my pad reach of about 500mm.
I haven't thought of BTA or computer mounts yet. I'll probably just keep my Xlab torpedo cage and see what real estate I have left for the computer.
2020 Races:
Ironman 70.3 Gulf Coast, Ironman 70.3 Hawaii, Ironman 70.3 Musselman, Ironman Chattanooga
Favorite Gear: Dimond | TriRig | Desoto Sport | Hoka One One
David,
My frame stack and reach is 540 and 425. My current pad stack and reach is 605 and 500. What's your recommendation on setup with the 70mm stem?
2020 Races:
Is that reach to rear? If not, which pads are you using (or just let me know reach to rear)
What is your pad width?
Center-ish of pad. TriRig Alpha X holders with CeeGees pads, which according to CeeGees are 110mm in width..
2020 Races:
He just said there's potentially a massive performance advantage associated with the integrated bottle. You're not going to try it and see if it works? I guess I'd probably give it a shot if I had this bar
Sorry, meant the width between armrests. It doesn't matter for the XY calc (as all the adjustments are independent).
You would need a Cobb or STS headset cover. The minimum I've used in the system is 9mm (as that is common) so a Cobb would get you right on the Y target and 1mm from X.
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [kileyay] [ In reply to ]
Not yet available. I'd also like to add that I'm not sure it would play well with the Dimond brake cover. I haven't found one single BTA system that "hangs" between the bars to work with the Dimond.
2020 Races:
Would I be better served with the 100mm stem?
2020 Races:
You can use the long stem, but your accuracy slips out by 0.1mm!!
To clear the dimond brake cover you're probably better with the long stem and it would give you a chance at the bottle.
You can see the Stevens has a bayonet here and here - the Bottle is a fair way ahead of the HT and the rubber gusset gets cut to match
Thanks! I ordered the 100mm stem. Despite it causing my fit accuracy to be off by .1mm.
2020 Races:
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [ggeiger] [ In reply to ]
Do you know of a Garmin mount that works with those extensions? The extensions are larger then the standard 22.2.
Timothy Winslow
https://www.instagram.com/timmywins/
http://www.timothywinslow.com
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [timmywins] [ In reply to ]
I am using the Garmin mount with the o ring type straps on a cheap clamp on computer mount and it works awesome. I wasn't aware that the extensions were a different diameter? This is the one I have....https://www.amazon.com/...ter%2Bmount&th=1
Which one are you talking about? Enve bar uses standard width extensions, I know because I've replaced them with Profile Designs...
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [jsk] [ In reply to ]
The extensions start out at the 22.2 standard size, then as they extend out they get thicker. Thats why none of the standard garmin mounts work.
Timothy Winslow
David,
David, same question but now with the 100mm stem. I'm going to build it up this weekend. Putting SRAM eTap on there as well.
2020 Races:
