Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [cyclenutnz] [ In reply to ]
I received the HSF Aeria bottle a couple of days ago. Installed it yesterday and it fits on my Dimond, barely, but it fits. No way it would have worked with the 70mm stem as it would not have cleared the Dimond's brake cover.
2018 Races:
INJURED
Favorite Gear: Dimond Bikes | Desoto Sport | Hoka One One
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [The GMAN] [ In reply to ]
would you mind sharing a few photos?
Re: Profile Design Aeria Ultimate aerobar and stem [The GMAN] [ In reply to ]
This looks pretty awesome...nice to see the computer mount moving forward....my preference is computer between the bar tips (learned from a st poster).....that way you can push buttons in aero and you can read it with the minimum movement of eyes from the road
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [frenchieTT] [ In reply to ]
It might be a bit before I can get some pics. My cockpit is currently a work in progress that I will finish up in a couple of weeks.
2018 Races:
INJURED
No worries. How much does the hydration goes down below the stem?
This is the question I would like answered. From the bottom of the stem to the bottom of the hydration reservoir, what's the length?
I sort of wonder if there is any bike with a TriRig Omega X or any external brake that would accommodate this bottle when the bar is at or close to the lowest configuration.
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [kileyay] [ In reply to ]
Yep, me too.
Thinking about the bar/stem/hydration combo on my B10 with omega x.
-shoki
No chance on your setup I would guess.
However, a flat kit or some such could be fashioned to hide the rest of your front end.
You know who to call for that.
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [chicanery] [ In reply to ]
Just yesterday, I received 2 of the hydration kits from Ceepo to go on my Viper-R frames. I have 2 of the bottles, but only 1 stem at the moment. The other stem is still to be shipped out. I mocked it up on my frame, and it looks good.
The stem is 100mm length, and rather heavy. The computer mount can be removed, and a second cover that's smooth fits in its place. The straw is big, and has a strong magnet to keep it folded down. The fill hole has 2 layers of star-slit-cuts to keep upspalsh down.
Happy to answer any questions.
Team Zoot-Texas, AltRED, and Pickle Juice
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [Taugen] [ In reply to ]
Yeah,could you measure from the bottom of the stem to the bottom of the bottle / fairing. Thanks
-shoki
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [shoki] [ In reply to ]
Sorry, it's not the clearest photo I could snap. Hope it helps.
Thanx a lot,another shot measured at the steerer would be highly appreciated.
-shoki
So that flat black (rubber maybe) material under the stem/behind bottle, do you trim that for best fit?
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [WatsonNh] [ In reply to ]
Yes.
2018 Races:
INJURED
Now that I finally have some of the bottles.
The unofficial answer to the question of "how low can you go with the HSF Aeria?"
The frame pictured has stack of 517mm, the headtube + headset cover is 110mm
The stem shown is the long (100mm) option
With a normal brake caliper
You can see that there is plenty of clearance vertically
The problem arises when we consider the caliper arm sticking out
It would be necessary to cut the gusset short of the head tube to provide clearance for the arm.
Could potentially fit on a slightly shorter headtube but would be a case of checking for a particular frame and caliper.
Would not fit with the 70mm stem at this height (arm would hit bottle).
Easier if we move on to centre routed calipers
The Magura would be beautifully hidden away. Once the gusset is fitted there would only be another 4mm clearance to the top of the caliper, so a 51cm NP2/3 or P5-Three would need a spacer under the stem to make it to 522 (as the absolute minimum) stack of frame +headset+spacers
Would not fit with the 70mm stem at this stack height
This image will likely not feature in the official fitting guide, but this mechanical centrepull caliper goes very nicely with the bottle.
Plenty of clearance. In fact you could go 20mm lower (probably, again this would require checking). Which brings it into scope for a 48 NP with a spacer under the stem.
Marginal on a 48 QR PR Series but good for a 50 (will not fit these sizes with a Shimano caliper)
Will it fit a 51 P4 with the steerer cut so short that you can't fit a spacer under the stem...No.
And finally - with the gusset on. Needs to be cut to match the headtube better. Will do that later.
Will attempt to put my bike together so I can field test too.
Connect - Velogic Fit l Facebook l Twitter
Or - Speedtheory l Facebook l Twitter
Perfect,thanx a lot for the effort to show it with different brakes.
-shoki
Would love to see this mounted on a felt IAx..
Am I reading that the bottle fits better with the 100mm stem?
Do we know if much testing has been done on rough roads with these? I had a garmin bike computer go flying at frankfurt this year when my torhans mount snapped :(
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [paulmartin] [ In reply to ]
That's probably bike and bike size dependent. As I mentioned earlier, the bottle would not fit on my bike if I had the 70mm stem. Dimond has a brake cover that protrudes out a fair bit and I barely clear it with the 100mm stem. My Dimond is a size M, which is equivalent to a L or 56 from other bike manufacturers.
2018 Races:
INJURED
thanks for this
Eric Reid
AeroFit | Instagram Portfolio
Chapel Hill, NC
Aerodynamic Optimized Bike Fitting, Retul Pre-Purchase Bike Fitting, USAT Level 1 Triathlon Coaching, Nutrition
Ask me: Scody Optimized Speed Suits | CeramicSpeed Oversized Pulley Systems | HUUB Skinsuits and Wetsuits | Ventum Bicycles and Frames
What caliper is that?
Re: Choice between the new ENVE SES Aero TT system or the Profile Design Aeria Ultimate. Which would you choose? [gary p] [ In reply to ]
Tririg Omega
-shoki
shoki wrote:
Tririg Omega
Ah, I was hoping there was a cheaper option. Not sure the tri-rig is worth the $ since most of the aero goodness is hidden under the shroud. Wonder if a Campag rear TT brake could be configured to work? They're only ~$40.
Funny talking bout pricing of a brake while thinking bout a 150$ waterbottle.;-) (not to mention the stem or the bar)
-shoki
Well, I'm looking a the the stem/bottle combo as a possible cheap(ish) way to aerodynamically tidy up the front end of a basic tri bike. The fact that it holds water is just a bonus.
That bugs me too. Testing is limited so far but what has been done shows that the bottle is far more significant than the marginal gains from the centrepull caliper. So it makes a lot more sense to go with the bottle and a cheap brake that doesn't block the gusset. Unfortunately there aren't any cost effective front centrepull calipers now - I can't recommend putting rear brakes on the front in order to use PD product.
Will see if I can find a Transition to test on as that would answer the question in a safe way.
