Hi Damon,
I recently went from a High-V position to a Low position with 25 mm FSA spacers and wanted to get a little input.[/img][/img][/img][/img][/img]
Do you think this set-up would compromise stability or aerodynamics or have any other negative impact? If yes, is there another way of getting somewhere in between the 105 mm stack of the High-V and the 60 mm stack of the Low position (I'm only using 1-5 mm spacer underneath the bar)?
Thank you,
Rick
Thank you,
Rick
