What are owners doing for TRAVELLING with their P5s? What are the bike box choices that are going to make life easy while protecting our investment?
I have a P5-Six, and have yet to travel with it. I don't think my IronCase that I have used (very successfully - zero damage to date) with my R3SL and P3 is going to cut it with the P5, especially given what appears to be some sort of magic act to get the front end disassembled. I'm looking at the TriAll3 cases, and wondering if the VeloSafe Pro Series Custom Road would work. I will call them when I get a chance, but looking for input from other riders.
http://triall3.com/...osf_cust_road_fs.jpg These are the Cervelo P5 travel instructions. I'm an engineer. I'm comfy with tools. I fix my own bikes. This is ... more than I care to do to travel with my bike:
Travelling with a P5
Remove the front brake from the fork. The removal of the front brake cover is not necessary.
Loosen the stem pinch bolts with a 4mm Allen wrench
Remove the high mount or the top cover if using the low mount of the 3T Aduro Aerobar.
Remove the top cap and drop the fork out of the frame.
Remove headset parts and place aside.
Remove the beard from the fairing mount.
Remove the rear derailleur, leaving the e-wire connected.
Lay the bike frame & fork into the case.
Put protective padding between the frame and the aerobar to prevent damage during transportation.
Wrap protective padding around exposed parts of the frame, rear derailleur, crankset, and fork to prevent transportation damage.
Place any loose parts (headset, bolts, etc) in a small bag. It is advisable to secure the small parts bag so it doesnt move around and cause potential damage.
Cover the frame and components with foam or other sufficient padding.
Remove the skewers from the wheels and attach them to the spokes.
Tighten down the straps and put the cover on the case.
