Leavitt wrote:
I just set up my P1 pedals and am using a Kickr, I know it's been said that transmitting via Bluetooth won't work, but transmitting ant+ is fine, I currently use my phone with TR, and will be getting an ant+ dongle for my computer to run TR moving forward. My main question for all you out there is regards to the watts difference, I have read that most have a difference ~5-10 watts, when on a Kickr, but when I go for a ride the Pedals are anywhere from 30-40 watts less than the Kickr at any given time. So when I get my ant+ dongle should I just drop my FTP by 30-40 and that would give me a relatively similar workload? Thanks
Hi,
Yeah, so using ANT+ with your P1 pedals will be more reliable power data as it totals the left and right pedals power and TR receives it. Over Bluetooth, it'll pair but only double the readings of one of the pedals which could lead to less-reliable power data. Both ways work, but you'll get a more accurate power reading over ANT+.
With that difference you're seeing, we actually have built into the app a feature known as PowerMatch to solve this problem. Instead of adjusting your FTP to account for the difference, you can implement PowerMatch which takes care of it for you. With PowerMatch enabled, we'll take the readings from your power meter and offset any difference in your pm's readings and your kickr's readings to make sure your kickr is adjusting resistance based on the power from your power meter.
You can learn more about PowerMatch here: PowerMatch explained
Feel free to let us know if you run into any other questions or concerns at support@trainerroad.com.
Thanks!
Get Faster with TrainerRoad
