Schwalbe Pro One 28c
Mounting:
Front mounted up with a floor pump without issue. Rear was a bit finicky. Had to take the valve core out, blast the tire with my compressor to get the bed onto the mounting shelf. Once everything seated, they held air without issue.
Size 30.7mm at 70psi on 21mm internal rims.
Pavement These are very much a road tire and roll as a road tire should. I believe Tom A has likened them to a GP4000sII, although I think I've seen them listed as faster elsewhere. I was faster on downhill and flat road sections for similar HR and effort as compared to the G-One on Strava.
I had no issues with pavement grip. With the reduced volume they had less of the "floating above the pavement" feel of the G-Ones.
Dirt Without question, they are less confidence inspiring than the 30C G-One speeds. If this is a concern, the G-One's are your huckleberry.
While the G-One speeds didn't have the grip of a knobby tire, they were fairly predictable in their drift.
The Pro-One's are a bit more On/ Off such that there isn't much "drift" and tend to move quickly to "slide". "Less forgiving" some may say.
I felt the difference on a high speed fire-road descent that has straight away speeds ~30mph into hard braking for switchback turns. On the ProOnes I felt I needed to slow more for the corners. On higher speed singletrack, crushed gravel bike path etc. I do not feel I lost any time as compared to the G-One speed. Certainly a bit less comfortable, but not slower.
The Balance:
This is what matters, in my opinion. In cyclocross I choose tires that are best for the majority of the course, unless the minority section is going to be the decisive point.
While I believe the G-Ones are more comfortable and confidence inspiring on the dirt section, I do not believe they are the tires I will run at BWR. For me, the road sections are going to be more important.
Personally, My skills on dirt are comparatively better than my ability to climb or motor along on the flats. I think I need to play to my weakness in a race that has 90+ miles of pavement with significant climbing.
I think that my last test-ride route was representative of what I expect from the BWR course. I also think that the Pro-ones were the best choice, for me. Ultimately we'll never know. We'll just get out there and have fun with what we have.
I talk a lot - Give it a listen:
http://www.fasttalklabs.com/category/fast-talk I also give Training Advice via
http://www.ForeverEndurance.com The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
