devashish_paul wrote:
Unless Daniella is an alien,
Which she obviously is not because she is Human.
her physiology should be not that much different from any human.
Essentially yes - not that much different. In detail - no she is an individual. Therein lies the problem with generalization.
She will essentially generate he same watts of heat for every watt to the bike wheel, and her ability to dissipate heat will be dependent on her volume to surface ratio and her percent body fat. Her percent body fat should be very similar to all elite pro women, and her volume to surface area should be pretty well identical to every pro woman of her height and weight. If anything, pro men generate more heat as they are doing more watts and their volume is relatively higher than women for their surface area, so they will have more trouble dissipating heat. The head is only a small amount of surface relative to the entire body. and the part covered by the aero helmet relative to a vented road helmet is an even small subset of our total surface area.
She may generate similar amounts of heat. She may have similar percentages of body fat. She may only cover a small part of her body like everyone else in the race. How this affects her performance is individual to her - as it is to Steffen (who has used aero and road helmets in the past and chose a road helmet this year) as it is to everybody else in the race. As an example, some will say it was very hot - probably come from a cooler climate to race. Some will say it was normal for that time of year - probably come from a hot climate or maybe even live on the island. That is all about perspective - you can perceive its going to be hot - you can perceive its going to be normal. That could affect your choice of equipment rightly or wrongly. The fact Steffen wore a road helmet is evidence enough that some think an aero lid is more of a hindrance than an advantage.
Throw as much science in as you like. Spread sheets, heat dissipation maps, thermal images - whatever you like. Its the perception that its either hot or its not that is the starting point. That is not science, that is not a spread sheet, that is experience and very dependent on where you live, train and can guide equipment choices.
So as much as it would be nice to think that Daniella defies basic physics
I never said she defied physics, I said a spreadsheet showing a 3 minute gain using an aero helmet does not mean she would be 3 minutes faster at the finish line, a statement that I believe is fundamentally correct.
Sutton, unfortunately does not understand physics, and that is fine. He gets awesome results out of his athletes, but he COULD get even better results out of them if you picked up the low hanging fruit that requires no actual training!
Whether Brett Sutton understands physics or not I have no idea, and I acknowledge the concept of what you are suggesting. I cannot and you cannot say whether Ryf would have gone faster at the finish line with an aero helmet, only she can. She/Brett chose a road helmet and it must have been for a reason.
http://mobile.twitter.com/BLambTriathlete Athlete of the Week Meet the Team Headwear
