trithink wrote:
Hi Damon,
I recently went from a High-V position to a Low position with 25 mm FSA spacers and wanted to get a little input.
[/img]
[/img]
[/img]
[/img]
[/img]
Do you think this set-up would compromise stability or aerodynamics or have any other negative impact? If yes, is there another way of getting somewhere in between the 105 mm stack of the High-V and the 60 mm stack of the Low position (I'm only using 1-5 mm spacer underneath the bar)?
Thank you,
Rick
Not sure if you can, but... If you move the plate to the top of the riser stack, just under the pads, it'd probably help decrease all of the force/leverage your arms exert outward. The only down side would be the bottle would be that much higher up, but it'd be no different than if you were running zero risers with a bottle between your arms. I hope that makes sense.
