The Good:
The Bad:
- I too was able to sync my v800 with my Android device this morning (which is great).
The Bad:
- On the syncing side of things when I try to sync with my iPhone it tells me "Sync Failed" every time but the data always gets synced with the app and into the Flow web interface.
- Since the firmware update yesterday the battery in the watch has been draining really quickly. I let it charge overnight and have had it off the charger for an hour and 1/2 and the watch is already down to 75% battery. I haven't even done any training today either.
- Power data is supposed to be in the .TCX export file but I've pulled multiple files out of Flow and gone through them and I see no evidence of a power variable. I'm using a Powertap and not the Polar/Look power meter so that may explain it. However, power data is power data and I think it SHOULD be in the export. I was using the Viiiiva bridge method because I still need the power data to go to my Garmin but I'll do a quick spin with the Powertap BTLE cap installed and see if I get anything different.
