mdlyons wrote:
I guess if I just want to compare A vs B for the purposes of which one is faster, using a fixed, made up Crr works (unless I am comparing different wheels with different tires). But I understand that if I want to arrive at a very accurate correct CDA, I need an accurate CRR. I am struggling to find the CRR for my training tires (Bontrager R3, with Butyl tubes), but a very similar model the R4 I see was tested at 0.0036 per bicycle rolling resistance.com. Am I correct that I would just double that number to arrive at the total crr? 0.0072 Seems kind of high when I see people for similar tests using crr numbers of 0.005 and it impacts the CDA by more than I had realized.
There are ways to solve for Crr but you need to be pretty careful about data collection in order to get good estimates because Crr is relatively "smaller" than CdA. The overall rule is this: the smaller the effect you're trying to find, the more careful you need to be in testing. A consequence of that is that it's easy to spot the difference between hands on hoods and hands in drops but if you're trying to spot the difference between two different front brakes you need to be pretty careful.
Crr is multiplied by weight, so what you're estimating is the overall average Crr for both front and rear tires. So don't double it.
If all you're doing is "Is A better than B?" then, yeah, you don't really need to get an exact estimate on Crr. If, however, you want to use this to know "*how much* better is A than B?" then you'll want to get a good estimate of Crr.
