ericMPro wrote:
mrfreeze wrote:
Thanks for the help here, Eric - very cool resource you're providing. You helped me on an earlier "critique my position" thread, so thanks 2x! Currently on a 2009 Trex TTX 9.5 and can't get enough scratch together for a new P5 so really have my eyes set on a ~2014-2017 P5 (or P3 if I just can't find one) - is it possible to still request help in this thread for an older ride?
If so here are my 3 requested measurements....happy to send more if helpful.
PadX = 416mm
PadY = 608mm
PadZ = 222mm (center to center pad width/separation)
Thanks for any suggestions/advice!
Travis
hi, thanks for reaching out.
That's not very much reach... you've got the stack of a 48cm or 51cm old P5 and new P5d, but your reach of 415mm is off the charts left for the old P5. For the new P5d, you'd be either a 48cm in the upper center of the range, and just off the back of a 51cm. Basically, the new bike ranges are "narrower" (and also longer!) than the old P5.
I'd be curious to see a picture of riding those fit coordinates... you might be a candidate for a saddle intervention which might effectively lengthen your torso.
Eric
Hi Eric,
Thanks for this, and apologies for such a delayed response. I'm still in the hunt for a ~2015ish P5, and with your feedback above on PadX I decided to go ahead with changes you suggested for me in my fit critique thread, by installing a 130mm stem last week. After that, since 130mm felt just a tad long, I also made a few additional adjustments to get comfortable including adjustments to the pads (brought them back about 10mm), the micro-shift levers (brought them back about 10mm), and the seat (raised it 20mm and brought it forward 10mm). Rode for ~5 hours so far and it's feeling pretty good. Here are my new measurements with these changes:
PadX: 431mm
PadY: 622mm
PadZ: 222mm (unchanged)
No rush, though I'm really interested to see where this puts me on the older P5 now. I probably have another 15mm I could move the pads forward on these PD 35a aero bars, so am open to hearing what the sweet-spot PadX would be on the P5 (if I'm not there yet).
Thanks again!
Travis
