BabaBooey wrote:
ericMPro wrote:
BabaBooey wrote:
ericMPro wrote:
BabaBooey wrote:
Hi Eric, i am contemplating a P-series as i am feeling ready to move on from my current QR CD0.1 and also want to take advantage of the disc brake capabilities on newer bikes. my fit specs are as follows:
Stack 537 mm
Reach 416mm
saddle tip to back of pad 415mm
my local shop is a cervelo dealer and they're great, i just want to get some insight from you because i cant get a new fitting now with covid restrictions as my current fit is 5 years old so probably due for an update on that front. i can send you my whole fit report, if that would help
Thanks,
Greg
hi Greg, thanks for reaching out.
Are you sure about that stack? That's as low as or lower than a 48cm bike can go I think. The CD.01 is a long and low bike now that I think about it.
Eric
Hi Eric - yeah that's what it is. i have a longer torso and shorter legs. i added the screen shot of the measurements here.
OK, so at your stack and reach you're definitely a 48cm P-Series. I'm worried about the stack, you might have to switch to the Profile Subsonic pad holders and extensions along with a aftermarket -17 stem.
Eric
wouldnt the 51 be closer to the stack & reach coordinates? this is why i think i need to do this at my local shop, if i need to adjust different pieces, they will have them to test out and make sure it works. my inseam is somewhere around 29.5-29.75" if that helps.
OK, let's start over.
You're saying your *pad* stack is 537 and your pad reach is 416. That's low, and too low for a 51cm as well as too "short". So, you're a 48cm. You would need to be at a minimum stack of around 560mm and reach of around 435mm at that stack to make a 51cm work.
Eric
