bluefever wrote:
klehner wrote:
furiousferret wrote:
I'm in the boat its a no win situation for the athletes. You're not passing a pack of 30 guys, the pack is just going to be too fast.
Did you come upon the pack of 30 guys from behind, by going faster than them? Why not just keep going faster than them and pass them? What am I missing here?
If they passed you, then they were going faster than you, and you have no basis for trying to pass them. What am I missing here?
I'm a bit late, but it is not as simple as that.
The fact you ask means you've never been in the situation, which means never a pack, which is cool :)
Here's what happens, and happened to me in IM Switzerland in 2009, and it ruined the experience somewhat. The problem is the 'pack' does not ride at a constant speed.
Say you are cycling at your power and 30km/h.
- You catch a pack doing 28km/h.
- You pass them, having to put out more power than you need to make the pass, say at 32km/h
- They latch on to you as you pass
- Now they start to pass you one by one due to the draft effect.
- Now you are mid pack, and a cheating drafter.
- The pack starts to slow, as the people who passed you don't want to keep up the effort.
- So - do you now put on a spurt, burn matches, and get to the front? If so, the same happens again as above. Or, you lift off and find yourself following a pack at 28kmh, slower than you could ride.
It's very annoying - in Switzerland there is 30km flat along the lake. After that the hills start and things break up.
On lap two I caught a pack just as described above and ended up in the middle for a few km, unable to put the effort in to drop it and watching it get slower and slower as I tried to slow.
It's really tough, and not as easy as you'd think. It's like a crit race pack - it ebbs and flows.
The footage from Texas is probably the worst I've ever seen, though.
Thanks for the polite description, rather than calling me names. Some questions:
If you are going 30kph, and the pack is going 28kph, why do you need to speed up to pass them? You have 15 seconds to pass each rider, not the whole group. How much faster do you need to go to dissuade this pack from speeding up to draft you, do you think?
If they then speed up to pass you, you are not a drafter until and unless they slow down in front of you (which can happen). This would seem to be a situation in which the rule to drop out the back of the draft zone should be ignored, and you should be allowed to pass immediately at your normal speed (which by definition is higher than the cyclist in front of you, and which should be a bit easier due to draft effects).
"Go yell at an M&M"
