Thanks! Fit is really flexible, pad stack height is currently adjustable on 5mm increments up to 40mm. Overall bar height can also be adjusted by adjusting the height of the stem. Bar height in aero is adjusted by the angle of the bar as it sits in the stem. Pad width is adjustable on 3/8" increments. I'll post some stuff on the site with fit photos and info.
First prototype I ran for over 2500 miles and would shift in both positions with mechanical shifters. It is easy to shift when out of aero lending itself well for climbing.
Now what about fit? What's the pad height/stack? How low can they be set? How high?
What about shifting while sitting up? Can you do that relatively easily with mechanical shifting? I'm thinking about climbing...
Thanks,
Frank
http://www.morf-tech.com
Staer wrote:
There ya go! That's the sleeker form I was talking about. Now what about fit? What's the pad height/stack? How low can they be set? How high?
Thanks,
Frank
