Great write up TJ, THANK YOU!
Great feedback by all, I'll try to answer everyone's questions best I can.
Arm pad spacers - you are correct, there will be a much shorter spacer under the pad support. There are several spacers that can be installed to adjust height. The ones seen there are about 12mm, standard will be 5mm. I agree, it looks pretty tall as the unit sits right now.
Safety - I completely understand this concern and appreciate the feedback here. This has always been my number one concern and number one priority. The second prototype that I put 2500 miles on was in no way even close to a refined product. I had the lock mechanism attached to outer portion of the bar where the hands make contact. This meant that the load of locking was taken through the cables which is not ideal. So I moved the lock in to the center pivot point for each bar end and energized it with a stiff spring. All loads from the locks are now centralized into as few components as possible reducing failure points. As Greenplease noted, there are two locks, one for each arm. Each arm is mechanically linked and one cannot move without the other. Both locks must be disengaged in order to move the bars, i.e. Redundancy. That said, what happens if the bars aren't pulled back far enough and aren't locked at all. On the first prototype, there were times during my training (on that not very refined prototype, not these bars) that the locking mechanism wasn't working at all. I could still manage it because the load applied is down and forward, not just forward. Tom, I think as you put it, we just need more miles on the product to get some folks more comfortable with it which is totally understandable.
Lock location - The bars are designed for a single lock position in the fully upright or retracted condition. The original prototype had a ratchet that locked in multiple locations but I found people struggled keeping the trigger released to allow it to go all the way to the aero position. With the single lock position, the lock is much simpler, more robust and reliable.
Again, thanks everyone for the feedback!!! I love the support. Stay tuned, presale is going to happen very soon!!
Thanks!
Frank
http://www.morf-tech.com
Thanks,
Frank
