Lot's of great feedback and questions - THANKS!!!
Change in Reach - The way the bars are constructed, you can put any length / style bar end you want on them. The video has short straights, but you could put longer straights, 30 deg, 40 deg, etc ski bends, bull horns, etc. We are putting a couple of bikes together with different bar ends, I'll update the site with pics. You can also adjust reach by adjusting stem length, lots of options there.
Maintenance - We are running ISO tests as well as testing tests outside ISO4210. During that test we will be measuring wear, cable stretch, etc. Contamination is a really good point, we will add to that test infusing contamination and salty water to the joints directly to see the type of wear we would see. We are using standard brake and shifter cables from Shimano. If the cables need to be replaced, it can be done, the only tools needed are a 4th hand tool and allen wrench. We'll put videos on YouTube on how to adjust tension or replace cables.
TruTri Schedule - We will be there all day this Friday. TruTri is having a grand opening of their new store. Stop by and ask for Frank or Greg.
Presale Date - We are stilling working hard to be in presale this month.
Thanks again for all the great feedback!!!!
Frank
www.morf-tech.com
Thanks,
Frank
http://www.morf-tech.com
