d00d wrote:
I have a few questions regarding the pre-sale pic.
Do you have to add all levers (gears and brakes)?
I see that bar ends are included. Will all aero bars work? I have a P2. Can I just take those bars and add them to this setup?
Does the popsicle mount work on all standard BTA setups, such as Torhans Aero 20/30?
Thanks!
Gear shifters are not included but any mechanical or electronic shifters can be used. Brake levers that can accommodate mechanical shifters are available. I am currently working on the final design changes that incorporate the brake lever into the bar assembly, more info to follow. If that design tests ok, they will be included in the presale.
Popsicle stick uses the typical bottle cage type BTA's. I really like the TorHans bottle so I will make an adapter for it as well but haven't gotten to it just yet.
If you want to use a different aero bar, could be used, but would likely need to be cut. The bar tubes that we are using are 7/8", 0.060" wall. I would be happy to look at your particular arrangement in detail.
Thanks!!
Frank
Thanks,
Frank
http://www.morf-tech.com
