Hi Ziv,
I can't see your image, but it sounds like the right adapter: 46 mm is the frame inside diameter. 79 mm is the frame shell width. 24 mm is your crank's spindle outside diameter.
Edited to add: Be sure to follow the BBright Press Fit Installation instructions exactly. Instructions are in a PDF which is linked at the bottom of the BBright.net home page, http://bbright.net/. Here is a direct link: http://bbright.net/...Fit-Instructions.pdf
The Rotor adapter won't work with your FSA crank. It's for Shimano and compatible 24 mm cranks. FSA uses 24 "plus" some tolerance; everyone else uses 24 "minus" some tolerance. Your FSA crank won't go through Rotor's bearings.
Cheers,
Damon Rinard
Engineering Manager,
CSG Road Engineering Department
Cannondale & GT Bicycles
(ex-Cervelo, ex-Trek, ex-Velomax, ex-Kestrel)
Cheers,
Damon Rinard
damon_rinard: Jun 12, 14 3:55
