Hi Erik,
Retul output, even better!
I read your stack height as near enough to 650, which happens to be the example row on our PDF.
So arm pad reach is next: I see someone already added a few centimeters to get from the back edge (Retul's convention) to the middle of the arm pad (Cervelo and others convention). The P5 pads are bigger than some, so I'll add 45 millimeters to get APR of about 483.
This puts you smack in the range covered by the 54 cm P5 with a High V bar, as you mentioned.
To your question: The bottom row in that box is with no spacers; every row above it is with 5 more millimeters of spacers. To reach your APS you'll have 25 mm. These spacers can be below the stem, or below the pads, or a mix.
The photo shows what looks like 15 mm below the stem, so throw in a centimeter below the pads and you have a winner. And ou're even thinking of going down a centimeter, which would make it a very simple swap.
Cheers,
Damon Rinard
Engineering Manager,
CSG Road Engineering Department
Cannondale & GT Bicycles
(ex-Cervelo, ex-Trek, ex-Velomax, ex-Kestrel)
Cheers,
Damon Rinard
damon_rinard: May 18, 14 17:17
