ABarnes and GreenPlease - you both are spot on. There is a new video coming out in about 2 weeks where I tried to show really working the bars, don't know if it is really clear though.
Ultimately it will come down to the product testing we plan to do. There is an ISO 4210 stem fatigue test that is quite stringent. We plan to perform that 3rd party test in two directions, one on the bar hinges and the other on the locks. In addition to that test, we plan on doing articulation cycle testing under load as well as static load testing in both the hinge and lock directions. I'll update the site with testing videos once we get all of those done, expect to be completed before the end of Q1 this year.
The forces acting on a handlebar can be three times your body weight, it is not wise to assume that how something appears to be made is indeed how it will act under load.
If you've never seen anyone snap a stem, clamp, or handlebar, it's not pretty at any speed.
I totally agree. I don't want to be Frank's PR piece but he's a proper mechanical engineer (oil industry) and he's told me the bars are being designed to handle very high loads and will be tested to that end (in accordance with... and probably well beyond... ISO standards).
Thanks,
Frank
http://www.morf-tech.com
GreenPlease wrote:
ABarnes wrote:
I'm afraid that is hardly proof. Tanks are indeed built like tanks, but even a 20mm projectile can breach the armor. The forces acting on a handlebar can be three times your body weight, it is not wise to assume that how something appears to be made is indeed how it will act under load.
Thanks,
Frank
