Thanks David,
I am normally a "low" guy, usually using a neg stem, however at the end of last season I did a bit of testing with a higher and more forward arm position.
I wouldn't call this a "superman" position, but with the arms at a slightly slacker angle and my chin really close (within an 2 inches or so) to the BTA bottle.
I think the HI-V would work well for this, but I need time in to see if it works on this set-up. So it sounds like its pretty easy to modify and I have switched cables around a lot on P3, P2 alu and soloist so once its set up in the Hi-V i think I wont have much trouble switching it to low if need be.
Thanks,
Maurice
Thanks,
Maurice
