In Reply To:
In Reply To:
People trot out this fallacious argument from time to time, but it flawed. For starters, as roady mentioned the forces involved in cycling are so far removed from maximal strength that your analogy is incorrect. More importantly, though, there is essentially no relationship between the fraction or percentage of maximal force and time to fatigue when said forces are so low. Or, to put it another way: dynamic exercise and isometric exercise (which is where the notion of relative forces arises) are two completely different animals.
My point was to attempt to illustrate how unsatisfactory the argument is. The statement "there is essentially no relationship between the fraction or percentage of maximal force and time to fatigue when said forces are so low" requires no less justification than the statement "there is no relationship between 1 rep max strength and FTP". Anyone who isn't convinced by the second statement will not be any more convinced by the first statement.
I had been hoping that you would respond to my later question, about relative ATP utilisation when comparing two people exerting their respective maximal forces of e.g. 200lb and 600lb, and then when the same two people exert a force of e.g. 50lb. I honestly am trying to understand why there would be zero relationship between 1 rep max strength and FTP, and I am sure that you have the knowledge to be able to explain it in terms that would convince me. I can see that strength training isn't going to train the mechanisms for aerobic production of ATP, which is why I'm thinking instead about ATP utilisation. If it is the case that the quantity of ATP required to exert a given force depends only on the absolute force being exerted, then that's it, the debate is over as far as I'm concerned. If, OTOH, the person with 600lb max strength utilises less ATP to exert 50lb of force than a person with 200lb max strength, then that would appear to be a possible mechanism by which someone with greater strength could have a higher FTP than someone with lower strength if they both have the same rate of aerobic ATP production. I truly do not know which of these is the case, so I'm asking the question to find out the answer, not to make an argument one way or the other.
Aren't you married to an exercise physiologist? She should be able to explain this all to you (if not, I question just how much she got out of her degree).
Anyway, to try to explain it one more time: the maximal
force that a muscle can generate is dependent upon how many cross-bridges can be formed between actin and myosin. In turn, this means that it is dependent upon myofibrillar "packing" (i.e., what fraction of the myocyte cross-sectional area is occupied by the contractile elements), the overall cross-sectional area of the muscle, and the extent to which the central nervous system can recruit all of the available motor units and their associated muscle fibers simultaneously (which generally isn't a limiting factor, as demonstrated by experiments using the twitch-occlusion method). What it does not depend upon is the rate of ATP utilization, as evidenced by the fact that the specific tension (i.e., force/cross-sectional area) of slow-twitch and fast-twitch muscle fibers does not differ, despite the much higher rate of ATP utilization by the latter. Similarly, it (strength) also does not depend upon how the ATP is supplied, e.g., from phosphagen stores or from glycolysis/glycogenolysis.
In contrast to strength, the
power that a muscle can produce is ultimately limited by either 1) the rate of ATP utilization (during very short duration efforts lasting only a handful of seconds), or 2) the rate of ATP provision, and especially how it derived (for all other efforts).
If that doesn't make sense to you, I'm not sure that there is much more than I can say, except perhaps to leave you with an anecdote:
Early in this decade, my wife was a national champion track cyclist, with a strength (average effective pedal force) during the pedaling motion at the time of 1100 N, or 112 kg (peak force would have been ~2x this, or ~225 kg for what is essentially a one-legged squat). This strength was the result of 1) large thighs and 2) specific training (lots of standing starts, etc.). Now fast-forward to 2007, where after 5 y of not touching a bike, two children, and a DVT that resulted in moderate to severe post-phlebotic syndrome, she decided to make a comeback in hopes of qualifying for the 2008 Olympic team. Since she had very little time to get fit again, we focussed her training on the primary determinant of performance in her event (i.e., the pursuit), which is cardiovascular and metabolic fitness (i.e., VO2max and LT). In just a few months (i.e., from late February to mid-July), she increased her functional threshold power from ~180 to 270 W, which was actually slightly
higher than it was when she won nationals originally. As a result, she set all-time personal bests for power for all durations >17 min. This was true even though her maximal AEPF at that time was nearly 30%
lower than before, simply due to "benign neglect" (i.e., lack of training aimed at increasing neuromuscular power).
