In Reply To:
Sorry to burst your bubble, but still going to argue. If ANYTHING, most of what you said only further supports the claim that true research is needed. (yeah, weather came in sooner than hoped so.........I'm back!).
I'll dissect what's been said and clearly illustrate the errors in a bit.
cheers,
but just off the cuff, before I go grab a shower and while garmin is uploading,
1. FACT is, that research that has been done, does indicate what people like coggan support, nobody disputes that. what is definitely under dispute is the fact that none of these studies was conducted in a fashion that could allow resistance training to produce a result other than "NO result".
2. definitions are definitions, but if someone tries to defend their position within the argument by commencing a shell-game with those definitions, then they are doing so for a purpose. The reader can decide what that purpose may be.
3. Gore is a world renowned expert too. So, I'd skip on this argument if I were you; it wont help.
4. I agree that the futility of the opposing view does tend to vex, when its so clear that they are wrong. the really great thing is that time will bear me out to be right, its just a matter of time till those same periodicals print peer reviewed data to support claims contrary to yours. Your world is not flat, you just haven't sailed far enough yet.
5. Sure their is, you just are
clearly unwilling to accept that you might be wrong, and you are unwilling to open
your mind to the possibilities that entails.
6. non issue
7. You aren't harsh.
Two comments:
1) I don't think anyone here - not even Frank - can be accussed of playing a "shell game" with definitions.
2) While it certainly
possible that future studies might demonstrate a beneficial effect of weight training on endurance cycling performance in competitive cyclists*, that would not:
A) change the fact that no such studies have been published*
as of today;
B) necessarily mean that these putative newer studies are correct and older studies are wrong, and/or;
C) prove that strength,
per se, plays a role in determining endurance cycling performance.
*As the saying goes in science, if it isn't published, it doesn't exist (which is just pithy way of saying that the onus is upon generating the data to share it with the world if they hope to convince people that it/they is/are correct).
**And if you go read the hundreds of posts I've made on the topic, I almost always state it that "There is no evidence that...".*** IOW, all I can do is summarize/attempt to explain the existent research literature; I don't have a crystal ball to see into the future.
***One of the reasons that I'm always so vociferous about this topic is in hopes of stimulating someone, somewhere, to try to prove me wrong. After nearly two decades of posting such comments to the web, though, it still hasn't happened.
