In Reply To:
In Reply To:
I simply do not understand your need to inflict others with continued academic bullying.
Sometimes the only way to get through to people is to be blunt about it. Since Jim is posting here, I assume that he is adult enough to not take it as a personal affront when someone disagrees with
his opinions.
In Reply To:
Several things:
1. While, as you state, in exercise physiology "how much someone can squat just one time (i.e., their 1 RM)
IS a measure of their strength" I would like to point out that you
did not say how much someone can squat just one time (i.e., their 1 RM)
IS THE ONLY ACCEPTABLE measure of their strength.
So?
In Reply To:
It is clear that your definition is not the only definition of strength allowed by exercise physiologists.
Sorry, but no: while there have been attempts by some to redefine strength as something other than the maximal force generating capacity of a muscle (or muscle group), such attempts have not gained any traction. Case-in-point: the American College of Sports Medicine still defines muscular strength as I have used the term.
In Reply To:
2. This is the internet. Few people at a site like this have similar backgrounds. People here tend to use lay definitions when discussing topics, not technical jargon.
Precise communication of precise ideas requires precise use of precise terminology. To do otherwise merely confuses things (as Jim's repeated inability to draw the distinction between strength and power/fitness clearly demonstrates).
In Reply To:
3. I believe the discussion is mostly about strength training and not max single leg squat strength.
While that may or may not be true, it really has nothing to do with my reply to Jim.
In Reply To:
Single leg squat strength has nothing to do with "strength training" as people use the term here.
Thank you for supporting my point re. how people often fail to use correct terminology (although I disagree with your claim per se).
In Reply To:
Even as you used the term it may even nothing to do with 5 sec power, since 5 sec power involves many more repetitions than one, at least the way most pedal anyway.
Again, thank you for supporting me: strength and power are different things.
Dr. Coggan,
Of course strength and power are different things. But, you are insisting upon using your technical jargon definition of strength on this non-technical site where the vast majority of the people here use an ordinary dictionary definition of strength. For instance, here is one:
strength (str
ngkth, str
ngth, str
nth)
n.1. The state, property, or quality of being strong.
2. The power to resist attack; impregnability.
3. The power to resist strain or stress; durability.
4. The ability to maintain a moral or intellectual position firmly.
5. Capacity or potential for effective action: a show of strength.
6. a. The number of people constituting a normal or ideal organization: The police force has been at half strength since the budget cuts.
b. Military capability in terms of personnel and materiel: an army of fearsome strength.
7. a. A source of power or force.
b. One that is regarded as the embodiment of protective or supportive power; a support or mainstay.
c. An attribute or quality of particular worth or utility; an asset.
8. Degree of intensity, force, effectiveness, or potency in terms of a particular property, as:
a. Degree of concentration, distillation, or saturation; potency.
b. Operative effectiveness or potency.
c. Intensity, as of sound or light.
d. Intensity or vehemence, as of emotion or language.
9. Effective or binding force; efficacy: the strength of an argument.
10. Firmness of or a continuous rising tendency in prices, as on the stock market.
11. Games Power derived from the value of playing cards held.
Here is another definition found when searching specifically for the definition of "muscular strength".
Definition: Strength refers to a muscle's ability to generate force against physical objects. In the fitness world, this typically refers to how much weight you can lift for different strength training exercises. The type of resistance can include dumbbells, barbells, resistance bands, machines, cables or your own body. When
lifting heavy weight, you increase strength, muscle size and connective tissues such as ligaments and tendons.
I see nothing in this definition that requires it to be for only a single repetition.
You state the ACSM defines muscular strength "as you use the term". Perhaps you could direct us to where that specific definition, that is referring to one rep squat strength, could be found. I would be surprised since squat strength involves a chain of muscle contractions in a specific coordination and doesn't directly measure any single
muscle contraction force. After all, we all want to be using the terms precisely, using the same definition, if possible. Perhaps you could help us all out here? Thanks in advance.
Frank,
An original Ironman and the Inventor of PowerCranks
