Re: Strength Training, Science vs N=1 [Andrew Coggan]
Could you point me to some reading to elucidate this distinction?
I assumed that anaerobic capacity = maximal production of energy anaerobically, but no eh?
Erik
Strava
Is this an argument for upper body strength training in cyclists? Or, could it be that they counter this excessive force by applying an upward force on the "recovery" portion of the stroke. The handle bars are not the only way such a force can be negated and they are not particularly well positioned to efficiently counter the torque that must come from shoulder muscles. Further, you didn't address the issue that the applied pedal forces are even greater than the calculated forces coming from average or even instantaneous torques.
Frank,
An original Ironman and the Inventor of PowerCranks
And, exactly what is the difference between anaerobic work capacity and anaerobic capacity?
Frank,
Re: Strength Training, Science vs N=1 [mcdoublee]
'fraid not, as this is my own personal distinction (my way of never losing sight of what the Monod approach really measures).
That is how it is generally used, yes.
Are you saying that "anaerobic work capacity" describes a limit as related to the cycling motion, whereas "anaerobic capacity" is a general limit for any motion?
Erik
Strava
Erik
Strava
Re: Strength Training, Science vs N=1 [Frank Day]
What is it that you do not understand? All measures of strength are movement/condition specific, so the maximal AEPF someone can generate when pedaling a bicycle is indeed a measure of their strength.
Most non-endurance track cyclists do indeed lift weights. Still, when you consider that performance in a standing start is only moderately correlated with strength (no matter how you measure it), I wouldn't advocate that anyone spend a lot of time trying to develop large upper-body muscles to counteract the forces that their legs can generate.
I'm not sure I understand what you mean...the fact that some of the points measured during the race were above the line formed by the data measured (using exactly the same equipment) in testing? As I said, that is probably due to 1) standing during the race (which has been shown to increase maximal power by ~10%), 2) greater motivation during the race, and/or 3) measurement error (no instrument is perfect, and the way that the SRM - or Quarq, etc. - measure power means that some bias in the data is possible).
I use anaerobic work capacity to refer to the y-intercept of the work-duration relationship determined using the Monod approach. I do so to constantly remind myself that the measurement is based on physical data, and not physiological data (i.e., based on such data alone you never really know precisely what accounts for any changes in this intercept, despite plenty of data showing that the y-intercept is responsive to interventions - such as weight training! - that would be expected to affect anaerobic capacity).
Sorry, according to you all measures of strength are 1 rep max measures. So, according to you, strength measurements cannot be movement/condition specific or are you changing the definition of strength that you insist everyone else use to what they have been trying to use. You did not measure the AEPF for your wife for one rep so, according to your definition, you did not measure her strength, as you have previously defined the term, the only acceptable definition of the term, according to you. Isn't that correct.
What I mean is, since applied pedal forces are almost never tangential to the pedaling circle the actual applied pedal forces are usually substantially above those that would be calculated from measuring torque (the only thing that can be measured if one does not have actual pedal force measurements), especially average torque for two reasons. Peak torque will always be greater than average torque and actual force is always greater than the tangential force unless the direction of the force is parallel to the pedaling circle where the force is applied. Hence, any statement that these calculated forces represent actual forces are a substantial underestimation.
Frank,
First, we know the Monod model breaks down at short duration efforts. Because of this breakdown it is not clear the Y intercept means anything in this regards.
Second, you make the assumption that the demonstrated effects of weight training (without defining exactly what kind of weight training you are talking about) only affect anaerobic capacity without any proof such an assumption is true. The entire argument of some here is they think weight training (again, without defining what they mean by weight training beyond meaning they are not looking to improve 1 rep max) could have an affect on aerobic ability also.
Frank,
No, per the ACSM (among many others), 1 RM is an acceptable measure of strength. There are, however, other acceptable measures, e.g., isometric force production.
This doesn't logically follow from what I have said in the least.
Nope: strength is the maximal force generating capacity of a muscle of muscle group. The fact that it can be measured different ways (e.g., 1 RM while squatting, vs. throwing some force transducers on a fixed bar and having a person perform an isometric movement at the mid-range of the squat position) in no way changes this fact.
No, it is not correct. I measured the maximal force generating capacity of her muscles during the cycling movement. Since measurements of strength are always condition-specific (e.g., your isometric strength with a 90 deg bend of the elbow is different than with a 150 deg bend), this wouldn't necessarily be exactly the same value as you would obtain using a different approach. Unless something goes awry, though, you would expect various measures of strength to be correlated (and they are, c.f. Stone's standing start study).
The calculated forces ARE the actual average effective pedal force - no ifs, ands, or buts.
(BTW, I find it ironic that you threw up that picture of Broker's TOTAL force data to talk about muscular forces.)
As roady said, you are clearly unfamiliar with the Monod approach, and in particular the data validating its interpretation. Specifically with respect to the y-intercept, it has been shown to be unaffected by hypoxia/hyperoxia (therefore must be independent of aerobic processes), but is affected by things such as very high intensity ("anaerobic") interval training or creatine loading. Thus, there is very good reason to view it as a measure of anaerobic capacity. Ultimately, though, it is based on physical, not physiological, measurements, which is why I try to consistently refer to it as anaerobic work capacity.
(BTW, the cause of the breakdown is clear: it is a result of both the model being too simple and the assumptions of the model being violated.)
No, precisely (ha!) the opposite is true: because I am very much a stickler for correct use of terminology to avoid blurring of concepts, I make it a point to refer to the y intercept as anaerobic WORK capacity.
And, I don't understand what is so ironic about the Broker/Lance data. Which is a better representation of the combined muscular forces during pedaling, Total resultant force applied to the pedal or resultant torque coming from the pedal?
Frank,
And, I find it interesting that you try to use a term (anaerobic work capacity) that, it seems, only you understand and have defined in your own mind. When someone asked you for a literature reference you said it didn't exist, as I understood it.
Of course, the breakdown of any model to predict outcome is a result of the model not being adequate for the conditions ("both the model being too simple and the assumptions of the model being violated") How can anyone say the model means anything under conditions where it is known to break down and keep a straight face? That is my point.
Frank,
Average effective pedal force @ CPV = 0.
There have been multiple such studies, but Moritani et al. (Ergonomics 1981; 24(5):339-50) appear to have been the first. (There are multiple review articles out there on the critical power concept, so I suggest that you start your reading with one of those.)
That is correct: most people use anaerobic capacity and anaerobic work capacity interchangeably, whereas I prefer to keep them separate (just as I once was careful to draw a distinction in a review paper between splanchnic glucose production measured using the a-v balance approach and whole-body glucose Ra measured using an isotopic tracer, even though many sloppily (IMO) refer to both as "hepatic glucose production"). You will note, though, that while I feel that this distinction is useful, I also recognize that it is my invention (as is the use of "metabolic fitness" as a synonym for LT, comparable to how "cardiovascular fitness" is used as a synonym for VO2max), and thus don't thrust it upon others (this thread only went in this direction when someone asked what I meant).
Because the conclusion that the y-intercept is an indicator of anaerobic capacity is based upon application of the model under conditions/experiments in which it does NOT break down.
Andrew Coggan: Jan 22, 10 12:36
Are you two billing anybody or their healthcare provider for any of this :)
Official Polar Ambassador
http://www.google.com/...P7RiWyEVwpunlsc2JtQQ
Re: Strength Training, Science vs N=1 [bmanners]
I suspect Andy may have been done for speeding or something and is performing community service to bring physicians up to speed with pretty basic scientific concepts. Personally I would have done time than try and teach Frank anything. I thought he was just playing dumb as this suited his business but recent posts prove an inability to follow basic principles. Inspires great confidence in the US Medical Teaching System. He was an anaesthesiologist so I wonder instead of gas or meds if he just talked people to sleep?
Sorry for the "snide" comments Frank, but it's all you deserve.
Hamish Ferguson: Cycling Coach
Just to illustrate this point: here is a quadrant analysis of a standing start workout that my wife did just a couple of weeks after the formal F-V testing:
As before, the solid red line is her AEPF-CPV as measured in the seated position on the Velodyne. The dashed red line, OTOH, is my eyeball best-fit to the data obtained during the standing starts (the points I've circled in green are clearly artifactual in nature). As can be seen in the figure, standing increased the force (and hence power) she could produce at low-to-moderate velocities by ~10%. Either due to developing fatigue or the difficulty in coordinating the effort when pedaling standing up at ~800 W, the slope of the line was steeper, such the two lines converge at ~70 rpm.
Continuing on this theme for a bit, what is interesting is to compare these data to a standing start workout she did back in 2002, as shown here:
http://home.earthlink.net/~acoggan/misc/id6.html
Her maximal AEPF back then (when standing) was ~1075 N, vs. the ~950 N shown in the above figure. IOW, she was 12% weaker in 2007 vs. 2002. Despite this, as I indicated before she set personal bests for power at all durations >17 min.
Andrew Coggan: Jan 22, 10 14:10
I live on soft money.
Re: Strength Training, Science vs N=1 [Kiwicoach]
No, believe it or not I do all of this of my own free will, and simply for the intellectual stimulation and entertainment value it provides me. Crazy, huh?
And I for one always appreciate it and do you the service of referencing any of the many concepts I "borrow" from your postings. Great post to the wattage site.
Before I start into this 13 page thread... can someone promise me it's worth reading?
Re: Strength Training, Science vs N=1 [tim_sleepless]
To be honest no.
To sum: Frank misunderstands something again and stubbornly digs his heels in and makes himself look even more stupid.
I feared as much.
