Dancollett wrote:
Hi Bryce, I'm hoping either you or Chad can help me decide which Specialty plan to use. My target race will be my 1st Half (17th Tri total) at Wimbleball in the UK, http://www.immortalsport.com/...eball-immortal-half/ it has 5,000ft of elevation with a couple of nasty climbs per lap, including one that tops out at 24%.
Since October I have been using Trainerroad and have so far done the Half Distance, Low volume base x2 & Build (to week 7), I have rest week next week an then I'm due to start the Specialty phase. It has gone well with decent gains in FTP, which made a big difference in my first race (a sprint) so far this year, -5 minutes on last year.
Given the elevation gain at Wimbleball am I better using a road plan (Climbing or Rolling Road Race) or sticking with the Half Distance plan? I swim with my club and plan my own runs, only using the Bike workouts from Trainerroad, so I wont miss them if I move away from the Half plan.
Thanks
Dan
Hey Dan!
I spoke with Coach Chad a bit and he had a few suggestions.
Firstly, we want to dispel the myth that a climbing course merits a climbing road race plan. Both the Rolling and Climbing Road Race plans are “race” plans. They account for massive fluctuations in power output which is not inline with the steady-state demands of a properly and evenly paced bike leg (that’s also followed by a run). The steady state approach of the Half Distance Triathlon plan is much better suited to your event and would be our recommended plan in this case.
That being said, there are a few other things that you can do to better prepare yourself for the climbs that take place in the race. For one, you should use a compact crank with a wide range cassette in the back. You should do some research and see the maximum cog size your derailleur can handle, and buy it. This extra range will allow you to stay within your power targets, even when the road tips upwards.
There will likely be times when even your low gearing can't save you, and you will have to lower your cadence in order to stay within your power tagets. In preparation for this, you will want to integrate a bit of slow force work into your training regimen. Slow force work is comprised of tempo to sweet spot level efforts, but in a 55-65 rpm cadence range. You can integrate these up to once per week during a workout that has intervals within the Tempo/SS range. Pay special attention to your knee alignment and make sure that your knees are tracking perfectly straight, without lateral deviation. If, despite keeping careful watch on your form, your knees begin to hurt, then abandon the slow force component of the workout and complete the intervals at a normal RPM.
I hope this helps, feel free to reach out if you have any more questions :)
Get Faster with TrainerRoad
