In Reply To:
In Reply To:
am thinking of getting back my old P2
In wind tunnel tests conducted at TAMU, the P2 had significantly more drag than my Hooker (complete with their proprietary "aero-or-die" handlebars, which provided a large advantage), which in turn had more drag than my wife's P3C.
Ok, but a P2 that I own only costs me the time to build it. I disassembled and loaned it out because I got frustrated with horizontal dropouts that would slip if I didn't tighten enough (leading to wheel rub on occasion), PIA rear wheel alignment (no set screws), and crappy shifting (problems with internal cable routing). I love riding the replacement, an Aluminum Principia that I bought for $150. It's stiff and solid.
While I'm hardly in the position to ask favor of you, given my contributions above :) I'd appreciate if you (or Tom A.) would be willing to give a SWAG on 40K TT time differential between following two setups:
P2 650c 56 or 57 cm size, with carbonaero fork
Principia Tri26 (fat 1.593" downtube, eggshaped but with 1 cm wide square trailing edge, relatively narrow round seat tube, teardrop shaped seat stays (sole aero advantage over P2), 650c, carbonaero fork
Assume all else stays the same. Yeah, including position. Cockpit is not very aero (round bullhorns and profile bars). Assume time around 1 hour. Wheels are 650c H3 (clincher). Prorace tires.
Thanks for any ideas you have.
________
It doesn't really matter what Phil is saying, the music of his voice is the appropriate soundtrack for a bicycle race. HTupolev
