In Reply To:
This looks like it might be a great technique for individuals to assess how changes might affect them
overall. Are they better or worse off for the change and by approximately how much.
Exactly. Isn't that the point? Faster is faster, right? :-)
In Reply To:
However, I can't see it as being particularly useful in comparing the aerodynamics of two bicycles, as was seemingly done here.
That just indicates that you don't fully understand the approach and the underlying physics of what is being measured. No big deal, a lot of people don't...
In Reply To:
Was the person doing the test blinded to the bicycles? Was the person evaluating the test blinded to the bicycles?
What would the purpose of the blinding be (besides perhaps causing the rider to crash)? Remember, the calculation is based on the recorded values of speed and power; Nothing else. Are you thinking that there would be some sort of "placebo effect" in the rider being able to telekinetically change the speed vs. power recording? You might want to think that one through again...
In Reply To:
How do we know the head was held the same the entirety of the two runs?
In this case, you'll just have to trust me ;-)
Seriously, what you point out is valid, but is just a part of using good experimental technique. To give you an idea of how well I can apparently "hold a position", in the past I've been able to get repeatability of ~.001 to .002 m^2 between separate runs of the same configuration during a session. Another thing to remember is that the "visual" nature of the technique allows one to see when things "aren't quite right" in that the laps won't be as consistent as they should be (i.e. the virtual elevation calculation "peaks and valleys" will vary inordinately). If you've read the whole thread you'll see that it was the excess variability in the second P3C run that I did which caused me to basically "toss" that run.
In Reply To:
Or, a myriad of other potential "problems"
Such as? I believe we've covered all the major ones...as Andy says "Asked and answered".
In Reply To:
However, if they feel what they are doing is aerodynamically advantageous (whether it actually is or not), this could help them psychologically. So, where is the racing benefit coming from?
Ummm...from going faster?
In Reply To:
Further, was a mistake made in the original calculations, in that the air density was not properly accounted for between the two runs? It would appear that a great deal of attention to detail must be applied here for this to be the least bit accurate, even for the overall number. I haven't quite figured out if this "error" refers to the original post or to a post on another site.
No. The ambient atmospheric values in the original posting are correct.
The error was made in that I posted a screenshot of an analysis of a TT I had run in comparing my spreadsheet to another rider's spreadsheet using his values. We were comparing them and I forgot to change the ambient values to the one's I had used. Even so, that "error" only changed the calculated CdA value by .002 m^2.
In Reply To:
Either way, it is one of those "detail" things that can greatly affect the results, which goes go my point.
It could...if you were WAY off on the inputs. But, as I said above, even that "error" only changed the result by .002 m^2...which is ~ the typical precision quoted for wind tunnel testing.
