In Reply To:
In Reply To:
In Reply To:
I went back & checked my records. I've got a private email from a reputable friend who was in a tunnel with a P2K and P3C, he quoted .5 - .8s/km @ 30mph.
Is that with or without a rider, and at what yaw angle(s)?
You tell me!
The Trek whitepaper data was, as you know, with a rider, and I said I was only quoting the 0' numbers . Looking back at it, it is roughly doubled at even just 10' yaw (if I assume the P2K is as bad at yaw as a Plasma).
Did I miss Tom's estimation of the apparent wind during his testing? If so, I apologize for bringing up the point, as it appears even minor wind could easily result in these sorts of differences once we make a couple assumptions.
John, I hear what you're sayin'...for example, assuming that the P3C is slightly (let's say ~.05lbs @ 30mph) lower drag than a Hooker Elite at zero yaw (as Andy has reported) and that the P2K isn't appreciably different from the original P2 at that angle, the data Andy presented in the post below indicates the difference to be around 0.2 lbs of drag, or ~.010 m^2 of CdA.
http://forum.slowtwitch.com/...oker%20drag;#1109749 So yeah...my "zero yaw" number looks to be at least double than what was reported there.
All I can say is the data "is what it is"... :-)
In regards to the apparent wind conditions, the testing was done in the early morning hours with the intent of minimizing crosswind affects. However, as I discussed earlier in the thread, even though in the past I haven't found much problem with dealing with slight winds on my original course, on this course there seems to be more sensitivity to winds, however so slight, due to the lower average and max speeds encountered. I have to emphasize however, that the amount of wind encountered during this test was
extremely light...in fact, I'm not even sure if it would have registered on a wind gauge.
Here's some more data that may help to serve as a "sanity check". Below is a plot from the first lap of a 40K TT I did a few weeks back on the P2K. As I mentioned earlier, the outbound leg of this lap provided an ideal opportunity to nail down a CdA and Crr since it was done in near zero wind conditions and the outbound speeds are high due to it being a generally downhill run. Knowing the actual elevation difference of the course was 50meters, and the fact that the wind didn't start picking up until ~1/4 to 1/3 of the way into the inbound leg, by choosing a Crr and CdA combo that matched the elevation difference and made the elevation profile symmetric about the turnaround point (up until the part where the wind started) I came up with a Crr = .0038 and a CdA = .228 m^2, which basically matches the "zero yaw" measurement from the field test.
Now, at the same race was another rider who is nearly the same size as myself and has a similar position on his bike. The main differences are that he rides a P3C and his wheels are slightly different (404 front vs. my TriSpoke, and tubulars vs. my clinchers) although that shouldn't have a huge affect on zero yaw performance. This other rider was, in fact, my 30s man so it's safe to say that we were both racing under VERY similar conditions. Using the same technique above, 2 things stand out. First, as expected, his Crr is higher due to the use of tubulars, and his CdA turns out to be .207 m^2.
So...knowing that, I don't find the difference I measured to be unreasonable, especially when considering Andy's data in the mix.
Oh yeah...the second lap of that TT was done with a steady wind. Using the Crr determined from the first lap, my calculated CdA dropped to .220 m^2 (just like in my testing when I
thought there might be some wind present) and IIRC (I don't have THAT data in front of me right now) the other rider's CdA dropped to ~.190 - .195 m^2. I know that's not super compelling data since it's 2 different riders, but it WAS under near identical conditions for both of us. The fact that the general magnitudes of the changes were similar lends some confidence (in my mind at least) to the results in the P2K vs. P3C testing.
But, I'll admit...there's some question about how
truly zero yaw my "zero yaw" measurement were. Then again, the data also points out how very little yaw it takes for the CdA to drop significantly on frames like these and further emphasizes how testing in a wind tunnel at only zero yaw can be misleading as to the differences between setups.
I'm thinking I might have to take the P3C over to my "preferred" course and do some runs prior to returning it to it's rightful owner. That's not going to happen this weekend though...since I'll be racing it :-)
