Figured I could post these publicly but if you want to take to PM that's cool.
160 cranks
Sorry for the freedom units
saddle height 30.25 - 30 7/16" to BB center. This measurement is kinda hard for me to guage.
saddle tip to back of pad: 21.75"
First sit down on the bisaddle with this configuration. Using the wedge that makes it more rounded and it's sitting at around 8-10degrees dpending on where i sit the level. This felt really good actually. Will be giving it a 2hr Sweet Spot test tomorrow.
https://drive.google.com/...Wa7/view?usp=sharing
ISM.4.0 6degree tilt. Been using for a couple weeks, and able to put out power just getting figety. Sore taint, nearing a saddle sore on the contact points and penis numbess
https://drive.google.com/...YXs/view?usp=sharing
ISM 10degree tilt. Figured I'd do this one at 10 since the Bisaddle felt good.
https://drive.google.com/...Xm5/view?usp=sharing
edit:Recorded on my gopro, but can redo on my phone if the fisheye is messing you up. If you download instead of using the web player they are much better quality
IG - @ryanppax
http://www.geluminati.com
Use code ST5 for $5 off your order
160 cranks
IG - @ryanppax
