This is absolutely correct!!! The theory that sugars are bad and only maltodextrin should be used has been refuted by numerous studies. A blend of various high glycemic carbohydrate sources is best! Fructose is OK, but too much and it too will wreak havoc on your gut.
Love maltodextrine. You need it for bulk calories because of its ability to get a ton of calories and keep it isotonic. BUT, you are limited to about 240 calories per hour (.9 gms/hr per kilo of body weight) that you can absorb with maltodextrine by itself. If you mix a combination of glucose, maltose, sucrose (and in some cases fructose) those absorbtion rates go to 1.24 gms/hr per kilo of body weight. That is 25-30% more calories per hour you will be able to process, a major difference in a long training day or race. If you are greater than 140 lbs, you might be running at a deficit.
Not saying it will not work for you, it's just not the most efficient and limits your ability to absorb calories. The comment I hear from Hammer customers is that the product works OK, but they tend to feel "flat". They notice a big difference when using a drink with the correct blend of multiple carbs.[/reply]
Robert Kunz / Founder and VP of Science for First Endurance
