Quote:
Sorry Ian, I just found my Retul Test from October 2019 in my actual bike. Look attachement (sorry its in spanish but the arrows in the picture can easy show you the measures) It looks like the PAD X is 452mm and Pad Y is 640mm. (it looks like I just made some errors measuring myself)
Also mentioning that already bought the New Canyon Speedmax DB in Size S, delivery will be next year, I am in configuration phase with them. But in their system with my 82.7cm inseam and 177cm height it told me to pisck up Size S.
SO what will be your suggestion now?
I am thinking long stem, flat bar, medium extension but waiting for your reply
Also can you help me telling me the size and number of spacers i will need?
Righ now in my bike I am running the Sync ergonomics ecosystem with 15-degree arm cup wedges, so I will like to keep a similar angle with the angle spacer. (Pic of my bike attached)
Thank you very much for your patience and support
Luis,
I'm sorry for the slow response. I'm glad you found the fit sheet and numbers aren't that far off - Pad Y 630-640, that's just a spacer. Pad X 480-452 that's something else. The small will work. You will need the long stem for the small. Flat bar is fine, medium extensions should be fine. I can't be precise on the number of spacers but I can tell you they should be easy to insert.
Keep me posted, Ian
Ian Murray
http://www.TriathlonTrainingSeries.com
I like the pursuit of mastery
Twitter - @TriCoachIan
