After some customization, I got one of these on my Shiv TT. I had to purchase the Felt version of the mount and the stealth bottle. I anchored it to the seat tube by protecting the frame, then using the velcro strip which came with the mount to secure it. It's also secured on the bottom tube by a screw drilled through the side. I may have to reinforce it with a washer, but it's tight and the plastic is as thick as the mounting area.
The one downside is that you cannot use this setup for liquids. I'm using it for a flat kit. The cut out is over the mounting screw so that it fits snug. I also used double sided tape, strong stuff, to secure the flat kit to the mount so that there's no wobbling on roads or in wind.
_________________________________
Fitness, Like Life, Is a Journey!
http://www.trifitcoaching.com
