Re: Scott 100k's recreated [Tom A.] [ In reply to ]
I have owned and used both the scott extremes and 100k and the 100k is a MUCH narrower bar...
If the extremes were slow (not surprising, like was mentioned harp, 2x round sections) the 100ks would definately be faster as the narrowness of the bars definately (especially in Tom's position) tend to lead and drag the arms:
http://www.printroom.com/...e_id=262&pos=263
Oh, and BMAN, keep cutting:
g
greg
www.wattagetraining.com
Re: Scott 100k's recreated [gregclimbs] [ In reply to ]
I could have bought those bars off of JEFF that had them before Christmas but I am thinking that I do not want to go that extreme. I would like to have a bit more bar and mount the brake levers under the armrest like Andrew had mentioned. I am not looking for a set up like pictured above but something more like a TWEENER set up. More aero than what I am using now but I want to play around with the set up so that I can actually use them in races as well.
AERO & LIGHT is RIGHT
Greg. What is the drag on the brake levers sticking down like that. I know that the Vision's are pretty narrow but it can not be good having them stick out like that.
Would it be better to have them mounted up higher on the extensions and in like with them so that they are more invisible?
Re: Scott 100k's recreated [jeremyb] [ In reply to ]
In Reply To:
Yep I bought a set too.
Hehehe...I feel like I'm fostering some sort of 100K bar revival ;-)
BTW, for any of you folks wondering how the handling is with them on the bike...I took my TT bike up and down a local twisty 3 mile, 8% grade hill today twice...the second time with a group. I had no problems leading/staying with the group the second time down. For those with motorcycle experience...the key to cornering with those bars is a heavy dose of countersteering :-)
To get a feel for the descent...check out this cool vid of some guys going down the same hill on longboard skateboards:
http://www.youtube.com/watch?v=kkviQ41u0eQ
In Reply To:
I think this pic captures the narrowness a bit better ;-)
Yep great pic.
Want: 58cm Cervelo Soloist. PM me if you have one to sell
Vintage Cervelo: A Resource
Re: Scott 100k's recreated [BMAN] [ In reply to ]
In Reply To:
Those are the same pair that I am giving to Jackmott for the 100k bars that he just bought. Also send him some Jagwire Shifter mounts. I can not wait to see his set up.
The jagwire shifter mounts that you were supposed to send to me????...but didnt????
have you thought of a way to attach a waterbottle or an aerobottle to those?
Dan
http://www.aiatriathlon.com
Re: Scott 100k's recreated [dtreeps] [ In reply to ]
In Reply To:
Nope...then again, I haven't given it any thought.
Re: Scott 100k's recreated [roady] [ In reply to ]
In Reply To:
how long does it take you to do the first 1000 feet of a flat TT with that set-up).
Sounds like a job for the new multi-file range analysis now found in WKO+ 3.0. ;-)
First 329 m after start w/ cowhorns: 32.0 s @ 349 W
First 334 m after turn w/ cowhorns: 33.0 s @ 359 W
First 334 m after start w/ aero-or-die: 31.0 s @ 376 W
First 338 m after turn w/ aero-or-die: 35.0 s @ 334 W
Same Wednesday evening 15 km TT done ~1 y apart...no significant differences in all-up mass, air density, Crr, or gear ratio (53 x 12 fixed gear).
Re: Scott 100k's recreated [IRONwolf] [ In reply to ]
In discussion about them I got the feeling that you did not want them and a straight across trade was fine.
PM if you need to discuss!
are your 100ks faster on the cervelo or the specialised?
I think a good thing to do would be determine a specific brake lever to be used and adapt the bends / cable routing specifically for those brake levers
Re: Scott 100k's recreated [garageman] [ In reply to ]
In Reply To:
For me, faster than my standard aerobar sets (Vision; Hed) on my Cervelo P3, P3C, and Airfoil Pro (since sold). Am building my bike for this season, a QR CD 0.1 and will be using the Scotts on it, too.
Re: Scott 100k's recreated [gabbiev] [ In reply to ]
Some one actually bought the QR CD 0.1 - Cool and I can not wait to see the finished prouduct.
In Reply To:
Photo of a preliminary build should be posted this weekend. It's a beautiful frame and I can't wait to get it into the tunnel. I do know that I like the seatpost design much better than the P3C's. Should be a very fast bike.
´Get the most aero and light bike you can get. With the aero advantage you can be saving minutes and with the weight advantage you can be saving seconds. In a race against the clock both matter.´
BMANX
In Reply To:
They are faster than my old bars on whatever bike they are on....
bumping an old thread.
did the new design go through? any other suggestions to improve the scott 100k bar?
That is super cool. Very "Kent Bostick".
Tom Demerly
The Tri Shop.com
Did anything ever come of this? I have googled my brains out looking for 100k's the better part of a year
Re: Scott 100k's recreated [tigerpaws] [ In reply to ]
Well, yes and no.
I had these made by a local welder, but never used them. They're sitting in a cabinet in the garage now.
dude that is some SWEET action!
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Michael in Fresno
"Do you spend time with your family? Good. Because a man that doesn't spend time with his family can never be a real man" V. Corleone
jeremyb wrote:
Well, yes and no.
very clever! How wide are the bars at the widest point? I'm not sure if I could go more narrow than the scott 100k's 25cm.
Re: Scott 100k's recreated [Nick_Barkley] [ In reply to ]
http://forum.slowtwitch.com/...string=100k;#3117571
14.5cm outside to outside
